Question about Uniden DECT2085-3 Trio Cordless Phone
Our phones were working fine anywhere in the house and now they all say "Out of Range" on all four phones and we don't have any idea why. Can you help please.
  • 35 Answers
Place the phone near the Transmitter if it says the same return it to the store
Posted on Apr 19, 2009
Turn Signals won't come on at all.
It most likely is the turn signal flasher. They are usually tucked somewhere under the dash. Listening to the 4way flasher may give you an idea as to its location. Also feel for the clicking of the 4 way flasher the turn signal flasher is usually near it.
Jan 20, 2013 | 1998 Buick LeSabre
Spectra profile performance jb960k0d1cc has power but neither oven and stove work
what type of power cord does your range have? is it a three prong cord or a four pronge cord. If it is a four pronge cord you must make sure that the ground wire is attached correctly on the back of the range. You can refere to your owners manual that came with the range on how to hook up the range cord.
Nov 14, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
How do you get a touch screen to work the phone is working but the touch screen isnt
LG has released a line of cellular phones that come equipped with a sleek touch-screen LCD display. Since these screens are high-tech and sensitive, they can be prone to damage or scratches. If the touch screen on your LG is damaged, and you don't have the money to take the device to a service technician, you can open up the phone and replace the touch screen yourself.
1. Turn off your LG and slide the back battery door down and off of the device. Lift the battery out of its compartment and use your Phillips screwdriver to remove the four screws located on each corner of the compartment.
2. Use your fingers to remove the back panel from the phone. The green motherboard will be revealed underneath.
3. Unplug the four ribbon cables that connect at the middle of the motherboard. Unplug the antenna cable in the top-right corner of the board. Lift the motherboard out of the phone housing and set it aside.
4. Use your Phillips screwdriver to remove the two screws located at the top of the phone housing, then separate the back frame from the front housing of the phone.
5. Lift the damaged LCD screen out of the phone housing. Replace it with a brand-new LCD screen (available from your LG retailer or online) and reassemble your phone in the reverse order you took it apart.
I hope you find it very helpful. Best regards.
Aug 18, 2011 | LG Vu CU920 Cellular Phone
Range rover seems to be running just fine but wont move in any gear
Sounds like you need to change your tranny fluid. If that don't help, Then you may need a transmission. But, before that, i would take it to youur auto parts store, and have them run there scanner on it. That will give you a better idea. Hope this helps, James Booth
May 17, 2011 | 2006 Land Rover Range Rover
I can switch on my phone but cannot dial anywhere. The range bar is showing nil. Please assist. I am not receiving calls either or cannot do anything from my phone
DEAR SIR...
THIS PROBLEM SHOWS THAT EITHER THE NETWORK IS NOT REACHABLE OR PROBLEM WITH YOUR MOBILE....
JUST GO TO UR MOBILE SETTINGS AND SCAN FOR NETWORK MANUALLY,IF YOU DON
Oct 05, 2010 | Cell Phones
I took the handset out of the house by accident and now i cannot make outgoing calls but i can still get incoming calls
Taking the handset out of the house should not cause any problem, the phone should work anywhere as long as it is within reception range of the base unit. Try unpluging the base unit for a short while and removing the handset battery. When you replug and reinstall the system may reboot. It may be that the unit just broke and that it was a coincentance that it happened when you took it outside.
Jun 28, 2009 | Lands Phones
Belkin wireless adapter
Sometimes wireless phones will interfere with the signals. If the router or PC is anywhere near a phone, it might have a problem. I have one wireless network card that gives me fits like that. I have yet to get a PC working with it. I have other wireless cards that work fine. I also switched to 5GHz phones, which helped my old laptop. Check to make sure there's not a conflict with the encryption used by either the dell or the router.
Jan 19, 2009 | Dell Dimension 2400 PC Desktop
GE XL44 Gas Range Clock Display frozen with only an "8"
This happened to me.  I just unplugged it and plugged it back in.  It worked!
Dec 03, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Only one burner of four not working
sounds like a bad switch in the knob, turn on the defective side, turn on the one that works and keep the clicking going then turn on the defective burner while "other" is clicking if this lights then it means you have a bad switch or loose connections
May 31, 2008 | GE JGBC20 Gas Kitchen Range
Uniden DECT2085-3 Trio Cordless Phone Logo
123 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
