Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
The CE is displayed on my upright kenmore elite, what should I do
    President:
  • 373 Answers
"CE" means the main board and the display board are not communicating. This problem is usually caused from a loose or broken wire. This can be at the main board located at the bottom of the cabinet in the compressor area, at the display board itself or in the door. First disconnect the power from the unit. You can now check for a loose wire connection, at the module under the cabinet or at the connection, at the bottom of the door. If the wires are ok, the display board will need to be taken out to check and the inner door panel may have to be removed to check the wires. Both of these parts can be difficult to check, even for a technician. I would recommend having a technician make these checks.Good luck with the machine.Please do post comments and results.
Posted on Apr 19, 2009
My kenmore upright freezer has a digital display that shows alarms. it is showing a ff and a ce code. can you tell me what they mean?
You have a bad freezer fan and need to replace it. The fan is located behind the back wall INSIDE the freezer. The unit will warm up a little because the air wont circulate the way it is supposed to. You can try unplugging fridge for 30 seconds to reset the control board u can do it yourself although I don't recommend it because u need actual diagnosis but this seems it hope it helps try buying part from sears or amazon
Dec 10, 2013 | Kenmore Freezers
Just bought a used kenmore elite frost feee freezer model 3 253.26072100 with an alarm and in great shape however there is no manual and we do not know how or what the temp settings should be at. We have...
You can view/download the manual at
http://www.managemylife.com/mmh/owner_manuals/8259/KENMORE-ELITE-Upright-Freezer-L0603500
Jul 16, 2011 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Washer won't start. shows CE on the display
That is a communication error between the control and the motor board.
Could be a corrosive buildup on the ribbon connectors and/or a bad wire or loose wire.
You can unplug the machine and trace all wires to look for a pinched or loose wire.
Unplug and clean all wire connections.
If that does not work it will be a bad motor controller.
Mar 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Top Loader "CE" error code.
CE means communications error
If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display.
Dec 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Sep 05, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
317 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
