Whenever I press the minus button, it automatically ads ANS in front of it. making it look like: ANS- I want to make a negative number by pressing the minus button and then the number but then ads another answer in front of it. Please Help.. PS: Also, the change of sign button seems to work as a substitute for the minus key.
Minus and change-sign are two completely different things. Minus is used to subtract one number from another. When you press minus when the input line is empty, your telling the calculator to subtract. The only way it can subtract the number you're about to put in is to subtract it from something else, and that something else is the previous answer, hence the "Ans."
If you want to input a negative number, use the change-sign key. If you want to subtract one number from another number, use the minus key.
Try pressing the plus key when the input line is empty. You'll get Ans+ in this case as well, The same with multiply and divide, among others, and for the same reason.
Testimonial: "Thank you, I understand now."
SOURCE: Button Problems
happened to me be4, except all my buttons didn' t work. I just did what people do in movies. throw it aroun, step on it, bang it against walls, desks , ect. Then my teacher took it away. The banging cleared all my ram. It was weird, but it started working.
I think the circuit board moved, and i hit it back into alignment.
SOURCE: TI-nspire calculator. I
Don't use the - key to enter a negative value. Use the (-) key located to the right of the decimal point key.
Make sure the printer is on and is connected to a working phone line.
Make sure that Auto Answer is on.
To check if Auto Answer is on:
From the printer control panel press the wrench sign.
Press the arrow buttons until Fax Setup appears, .
Press the arrow buttons until Ringing and Answering appears, and then press
OK to save the setting.
Press OK again.
Check to see if Auto Answer is set to On.
If Auto Answer is not set to on, press the arrow buttons until On appears, and then
press to save the setting.
Set the number of times the telephone rings before the printer automatically
receives faxes:
Press the arrow buttons until Pick-up On appears, and then press OK .
Press the arrow buttons until the setting that you want appears, and then press to
save the setting.
When the number of rings you set is detected, the printer automatically receives
the incoming fax.
This should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
