Nokia C6 Smartphone Logo
asadkhan Posted on Sep 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Display not working ic - Nokia C6 Smartphone
Eric Shields
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 112 Answers
  • Posted on Sep 23, 2013
 Eric Shields
Expert
Level 2:
New Friend:
Cheetah:
Answers
112
Questions
Helped
8219
Points
199
Another display issue. Did you crack the screen? Did it suffer water damage? Is it OLD? is the battery worn out? How do you know it's just the screen? Answer these before leaving out always-important details.
My nokia 6303 classic display is not working but i can recieve the call and all i asked in shop they said ic is gone ,,so can it be fixed n what will be the cost of original ic
Hi.There is no Particular display IC (filter).The tracks of the Display is directly connected to Rap IC.If the Rap IC is damage there is way to fix this.It can be only repaired by making jumper or replacing of LCD socket.The cost will be charge between 300 to 500 INR.You can see it from this 6303 display ways .Thanks for visiting fixya
1helpful
Kenwood krf-v4060d receiver display problem, its work for some time but after that no display, sound work fine but not able to see any display on receiver
it is possible that the voltage to the filament of the display is absent. This is normally a 3.6 volt AC which comes from the transformer and it can be lost a the connectors or the circuit board. It will be best to use a multimeter to trace the voltage to the display unit. check the voltage to the display driver IC, check the negative grid voltage to the display , if there is an open resisitor of the feed to the display voltage to the IC. Finally check the continuity of the filament of the display unit.
The driver IC is also a suspect , sumulate heat and see if the fault comes up easily which can confirm the case.
Oven display is completely out buton work but no display
Since all the buttons are working properly the problem is on the display control IC. Open the control panel of the oven and replace the IC.
My phone model no. 1600 black not displaylight ?
it is the main displays problem!! sometimes it is just because of an IC or it may be the displays problem! u show it to a technician and tell him to put a working test display! if it works the replace your display, or just replace the display ic and see.
reply and rate!
N-70 Light problem
go to display setting and then high the brightness
21helpful
5answers
My nokia 6085 mini display wont light . You can see the time displayed but it is dark.
change the display IC near the main board strip connector, there r two ICs the one on the right side is for mini display , re heat it if it doesn't work after changing the IC ;)
153helpful
7answers
Nokia n95 8gb
i think after all that you should replaced the mainboard
7helpful
5answers
Keypad light n display light not working
display light and keypad not working i have changed keypad light ic and keypad coil what to do?
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
