Question about Canon PIXMA MP210 Photo All-In-One Printer
Error 3, paper jam
Error code 3. Says paper jam, but no paper. Will feel one sheet through without printing, then the second sheet goes half way through then stops, and error 3 comes up as a paper jam. Its like it's misaligning the paper, and I don't know how to fix it.
  • steele_eric Apr 30, 2009
    having this exact same problem, please help!
  • Anonymous May 13, 2009
    appeare 1,3,E in display and all color and black and i led is on
    please help me for this proplem
  • 66 Answers
Use an antistatic vaccum or canned compressed air to clean the interior of the printer.this problem may cause by dust and debris inside the printer.inspect for any broken part in the paper path.if u find any u will have to investigate repairing or replacing the printer.
try using different weight paper .some printers work best with the particular weight of paper and if you use paper too thick or too thin jams can usually occur.thanks
Posted on Apr 19, 2009
SOURCE:
Error code 3528 keeps coming up,telling me to remove back cover and remove paper jam then replace back cover.there is no paper jam,checked printer heads no paper anywhere?
I have this printed and if you read (carefully) through the manual it tells you it doesn't like single sheets of paper. If ever my paper feeder tray runs below say 3 sheets then this error will crop up so keep it topped up with paper. The same goes for photo paper too.
Sep 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Paper goes thru printer without printing
Look if you do the paper correctly in the printer and if you have enough colour to print then it should go^^
Sep 09, 2009 | Epson Stylus C120 Color Printer InkJet
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
PAPER JAM ERROR 201.02
if you are gettiing a 201 error without any paper in the printer you will need change the main motor drive if it fails to initialize this is the error that will show up and there is no other way to reset it
Mar 20, 2009 | Lexmark T640 Laser Printer
Printer jam Lexmark X3650
user guide in there
http://cluetechnologies.com/index.php?topic=687.0
Jan 29, 2009 | Lexmark X3650 Printer
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
343 people viewed this question
Clive
Clive
old marine
old marine
