Question about HP Officejet 7310 All-In-One Printer
Printer tells me to install new color cart. after i have put in new hp cart.
Hp printer 7310, printer tells me to install color cart. after i have put in new hp cart.
  • Anonymous Mar 12, 2014
    hp deskjet 1000 indicates failed cart. with new cart installed
  • 385 Answers
1. Press the Setup button.
  1. Use the arrow keys to select Tools and then press the OK button.
  2. Select Clean Print Cartridge and then press OK . The device prints a test page.
  3. Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.
  4. Open the Printer Toolbox . There are two ways to do this:
    • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
  5. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
  6. Remove and re-insert, while the product is switched on.
If still bad, swap out the cartridge.
Hope this helps
Regards
Posted on Apr 19, 2009
Printer does not recognize new ink cartridge
Are you using "refilled" hp cartridges? If so, they may be interpreted as "empty" or a non-hp cartridge if the carrtidge shell was manufactured prior to the recent time that hp began coding the electrics on the same type cartridges. This can also happen if you are using "compatibles". If this is the case, try buying original new hp carts. If that is what you already have, return the cart to the store as defective and as for a replacement.
Apr 28, 2010 | HP Photosmart 3210 Printer
Problem for HP OfficeJet 7310 All-In-One InkJet Printer Hp 7310 print cartridge alignment failed
You must replace all ink carts with GENUINE HP carts to get a sucessful alignment.
Jan 19, 2010 | HP OfficeJet 7310 All-In-One InkJet...
How do i install a toner chip on my hp Cp2025
They're called "toner cartridges."
- See the instructions that came with your printer, but here are the basics
The HP Color LaserJet CP2550 has 4 toner cartridges, one black and three color. Only one cartridge can be changed at a time. They are on a rotating carousel. So you first press the Rotate Carousel button until the cartridge you want to change is selected, then turn off the printer, open the top, pull out the old cartridge, put in the new (being sure it's the correct color), then pull off the tab that keeps the toner from leaking.
HP's toner cart installation instructions are at
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00242813/c00242813.pdf
and the general manual is at
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00242826/c00242826.pdf
toner cart stuff starts on page 12.
If your computer will not open these pages, you need the free Adobe Reader, get it from
http://get.adobe.com/reader/
(I suggest you click to uncheck the "Free McAfee Security Scan Plus.")
Nov 07, 2009 | HP Color LaserJet 2550n printer + HP Color...
Hp 7310 does notbrecognize new color printer cart.
  2. Use the arrow keys to select Tools and then press the OK button.
  3. Select Clean Print Cartridge and then press OK . The device prints a test page.
  4. Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.
  5. Open the Printer Toolbox . There are two ways to do this:
  6. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available.
  7. Discard or recycle the page that prints.
If still having problems, swap out the cartridge.
Hope this helps
Regards
Apr 19, 2009 | HP Officejet 7310 All-In-One Printer
Problem with replacing color ink cart. #5
Is it the right Cartridge you are trying to install please check and then check if the sensors are working.
Mar 31, 2009 | Lexmark X2600 InkJet Printer
The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 printing crooked. New HP cart installed.
There is a back panel that opens up by turning a knob....remove that panel and view for any paper pieces...
keep me posted if this didn't help!
Nov 11, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Color ink cartridge
hi, if your printer is telling you that you stillhave to replace the cart even if you have just replaced it with a new one, it might be that the one you are installing is defective. you can try installing a different cart. if this issues persist, then i suggest you contck kodak's tech support hotline 800.421.6699
Oct 23, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
HP PSC 950 print problem
It is cheaper to buy a new one than dewll to fix an old printer.
So called experts can tell me only by asking stupid questions
like; "did you turn the power on?" did you put a paper in it? did
you check the ink cart and so on". Duh!
For the sake of HP making more money, I have sent this printer to its
eternal resting place. Problem solved!
--Sam
Jul 12, 2008 | HP PSC 950 All-In-One InkJet Printer
83 people viewed this question
Seeker5211
Seeker5211
