Question about JVC HD-61G787 61" Television
Im not getting my video
I have a ps3 and i I'm using hdmi what can I do for a factory reset
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 105 Answers
You cannot do a factory reset. If the HDMI doesn't work because it was deactivated or something
1. press "sleep" on remote so that "sleep 0" is displayed
2. press "video status" and "Display" simultaneously
3. You should be in the Service Menu
4. go to "self check"...i think it is #3
5. press the "power" button on the remote
6. unplug TV and wait 5 seconds to plug it back in
7. check to see if it worked
This reactivates the HDMI input if it gets deactivated. Also, make sure you got the PS3 setup right. Set it to Auto....I don't think this TV does 1080P so don't expect it. I know it can't do 1080p/24 which is what the PS3 puts out with some 1080p movies.
Posted on May 18, 2009
Samsung 2007 27" TX-T3092WH will not support HDMI or cannot see PS3?
HI,
Do one thing While PS3 is in standby mode press and hold the power button on the frond panel of PS3 for 30 seconds (factory reset). After doing this you will get video from its composite video.
Also check the hdmi If you didnt get the video through HDMI then,
PS3 out puts Full HD 1080P video through its HDMI out put. IF your tv doesn't support Full HD then it will display format not supported or Software not support.
If you want to get video through HDMI then do the following.
Connect the PS3 to any Full HD tv (friends or relatives) and go to its menu ,select HDMI settings. then down scale the video from 1080p to 1080i.
After that connect the PS3 to your tv you will surely get the video.
Ajin
Jun 16, 2012 | Samsung TX-T3092WH TV
I HOOKED MY PS3 UP TO HDMI LAST NIGHT AND NOW I WANT TO GO BACK TO AV CABLES AND IM NOT GETTING ANYTHING
when the system is in stand by hold down the power button for 15 seconds and it will do an auto - video reset to the used video component. same works if you want to go back to hdmi just hold it down again.
Jun 14, 2010 | Sony Playstation 3 (PS3) Console
Cannot get signal on tv but all lights on likeit
Put PS3 into idle mode (red solid light). Press and hold the power on button for about 5 seconds until you hear one beep. Then let go and wait to see if it now comes on.
Mar 26, 2010 | Sony Playstation 3 (PS3) Console
My PS3 was working for 10mon, one day the audio over HDMI started to crackle. On dolby encoded media it would crackle and skip with an odd distortion. If I use any audio output other than HDMI on the PS3,...
sound like ur speakers are failing lol im a genious right... u probabily figured that out try playing something else through ur system not ps3 if it still crackles u should think about changing your sound system
Nov 13, 2009 | Sony Playstation 3 (PS3) Console
I have the same problem with my Samsung LE46A656 A1F Full HD
If it was doing it on your old console then its the TV not the PS3.
Causes: HDMI cable (Replace cable), HDMI socket on TV (Get it repaired), If it happens on all HDMI inputs then the video board maybe faulty, Interference - location of PS3 to other equipment.
The first thing to do is move everything else away from your TV except for the PS3, now factory reset the Samsung TV and make sure your firmware is up to date my records show that an update came out in May for your TV, also factory reset the PS3 and setup the HDMI video settings using the wizrad in the PS3, now connect the PS3 through all HDMI inputs to see if its one input or all, if all inputs are the same then the TV maybe faulty.
Let me know how you get on.
Thanks
Sep 05, 2009 | Sony Playstation 3 (PS3) Console
No video on PS3
Use regular A/V cables on the ps3. Turn off the PS3 from the back. Go ahead and hold down the power button on the front and as your doing that turn on the ps3 from the back and keep holding the power button on the front for 5 seconds.
At this point it should reset the machine back to factory defaults and you should get video. Go ahead and change the video output to HDMI and reboot the system. On the reboot you should get video from the HDMI output, if you don't then that means you have a bad main board inside of fthe PS3.
Aug 19, 2009 | Sony Playstation 3 (PS3) Console
Hd port on back broke need to reset video to use av cables any help???
Press the power on the PS3 for 5 seconds (in standby mode) till it beeps thing to reset the graphics output
May 29, 2009 | Sony Playstation 3 (PS3) Console
Blank screen for demo's
I was have the same problem with F1 only and I did the reset .
That fix my problem
Hard Reset procedure for the PS3 (as instructed by Sony CS).
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves!
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
May 11, 2008 | Sony Playstation 3 (PS3) Console
JVC HD-61G787 61" Television Logo
212 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
