Room a/c unit wont turn on
There is power at the outlet i double checked. unit is 2 years old.
  • ctmeade Apr 19, 2009
    Unit is exactly 2 years old, turned onto A/C today from heat and unit does not work, after 1 year they had to install a hard to start and it has now failed, the company that installed it does not want to back up any guarantee or warranty on this product i need someone to email me at ctmeade@windstream.net If i can get a new compressor or another unit at discounted price i will have a good quality Heating and Air company install it.
Junked it and got a new one
Posted on Apr 21, 2009
How do I fix the electrical outlets in our family room? The room has 5 outlets, one of which works. The other four have no electricity. I replaced one outlet but that did not correct the problem
Check for any tripped breakers. Make sure a wall switch is not controlling any of them or that they are not on a GFCI circuit. If all OK, turn power off to outlet that works. Remove the covers from each outlet, and pull the outlets out of each box as far as you can, but leave the wires attached to the plug, making sure none of the wires contact any part of the box if its metal. Look at the wires attached at each outlet if they are not attached to the side screw terminals, but rather pushed into the back instead, note the way each is attached, then either cut them off as close to the plug as you can or pull them out of the back. Now reattach them in the correct place but put them on the screw terminals instead. Make sure all wires are secure. Turn on the power and carefully test each outlet for power. If they all work, turn off power, replace everything and your good. If still no power at any of them determine which outlet(s) have only one cable entering the box. The boxes with one cable will either be on its own circuit, or the last one in the run. The boxes with 2 at least 2 cables will be the middle of the run and one of those will be the one with the power supply for all of the others. If you don't have a signal tracer try locating tracing the wires from the 2 wired boxes in the basement, one of those wires is the feed and could be disconnected at a junction box or at the service panel.
Mar 21, 2015 | RCA 6 Conductor Modular Wall Outlet
How to connect 2 lights from wall unit to wall plug
the electrical department in Home Depot or Lowe;s have double , triple adapters for outlets. BUT You need an Electrican to rewire wall switch for a switch control of an outlet....just like in a living room when you enter from outside.. it turn your lamps on.
Dec 04, 2011 | Pioneer Audio Players & Recorders
I bought the heater around 2 months ago. It was working fine earlier but now it wont turn on. I have unplugged it and let it sit and am still unable to get it turn on. I checked the outlet and that is...
hello, Most all new heaters of this class have integrated controls that are part of the unit itself that are highly sensitive to power surge's and shorts. If the outlet it is plugged into is live and working the most likely a bad control board. These units almost always come with a minimum 2 year warranty most of the time more and seeing as you bought it recently i can help you find the proper information for retrieving the warranty if i know what retailer it came from IE: walmart, Amazon.com, buy.com, eBay, ETC.
I have a cabin in a area that has many power outages and surges due to old utilities and i use either a GFIC outlet or a single outlet surge protector (after a few problems of the similar type.
if you need anymore information or have any questions please let me know.
Feb 09, 2011 | Honeywell HZ-709 Oil Filled Radiator...
My dishe washer wont turn on
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced
Now, if you have confirmed that the unit is receiving power from the outlet, and the unit is still not responding, this will lead to a failed control board, or timer module. replace either the timer, or control board, in this case.
Nov 05, 2009 | Dishwashers
Lexmark z31 printer will not stop printing
Disconnect printer cable from PC. Power off printer and unplug power cord from outlet. Wait 15 seconds. Press the power button as if to turn on with unit still unplugged. Plug back into outlet and turn on printer.
Before reconnecting to PC, check the printer's queue status. Start, Control Panel, Printers. Select the printer by double clicking to open queue status. Select any remaining documents and choose cancel from document menu bar.
Bret
1-2-1ComputerServices
Oct 04, 2009 | Lexmark Z31 InkJet Printer
Emerson tv wont turn on
I would check the fuse first
Mar 24, 2009 | Emerson Televison & Video
My problem is with my 1 1/2 year old Sylvania hdtv. I turned it off yesterday morning and it won't turn on. I have left unplugged overnight for the "factory settings" to go back into effect. I have...
Check the outlet to be sure you have power to it. Then check both ends of the tv power cord to insure that they are actually plugged in. good luck.
Jan 23, 2009 | Sylvania SRT2232S 32" TV
Hp psc 2210
1.) Double check the power outlet that your printer is pluged into. Swap to another outlet. 2.) Double check the plug at the printer end, it may go in only one way. Still no power when you press the power button? It may be bad. Return it.
Dec 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
My air conditioner stopped working.
lets check do you have plug something els in the outlet to check for ac curent? the cable of this unit have an overload braker? need more info but better call a tech...good luck
Aug 11, 2006 | Kenmore 6000 BTU Single Room Air...
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
