Question about John Deere Garden
I need a gas tank for a John Deere backpack blower. Model # M0005EA.
boscia
  • 163 Answers
SOURCE: I need a replacement gas cap
try www,jackssmallengines.com
Posted on Nov 30, 2008
SOURCE: Hello. My John Deere mower has started surging at
I have a john deere 420 rider. It would surge at a higher speed. It is a hydrostatic and there were 2 bolts on the transmission that were loose. now it runs beautifully smooth,
Posted on May 04, 2009
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
SOURCE: need owner's and service manuals for John Deere Model 317/
First off, Mowerman's response was incorrect about the age of a JD 317.  They were made from 1979 to 1982.
You can only get manuals either through here:  http://techpubs.deere.com/deere/Default.aspx  or from a dealer.  They're expensive.  You can find them on ebay and also here: http://www.ssbtractor.com/tractor_manual_display.cgi?m=John%20Deere&o=317%20Hydrostatic but I haven't used that site.
Posted on Oct 27, 2009
rwvanlue
  • 486 Answers
SOURCE: My Homelite backpack leaf blower runs until tank is 1/2 full
I believe you to be correct in your diagnosis.
1) remove the fuel tank
*this will give you an idea of how lines are routed and fitted into tank
2) install a new hose through to tank fitting and make sure to retrieve the old hose & filter inside the tank, so that you can attach the filter to the new hose. The filter is weighted so that it falls to the lowest point to pick up fuel.
Posted on Nov 13, 2009
Can I install a GAS SHUT-OFF VALVE on my John Deere D130?
just drain the tank, find the fuel line and put a valve in the fuel line like on snow blowers and lawn mowers.
Jan 18, 2015 | John Deere Garden
The gas tank on my stilh 420 blower is craked and keaking need to replace tank
Look for a replacement tank online! They are available and resonaably priced too. you will get new fuel lines and a new gas cap too! Bonus
Nov 10, 2013 | Stihl Br 320 340 400 420 Backpack Blower...
It starts easily but turns off after about 10 to 30 seconds
I suspect a fuel supply problem. filter could be plugged. I just went through this yesterday with a john deere. After looking inside the gas tank I found the filter still hooked up to a hose that had broken off inside the tank. New hose's and some fiddling around fixed mine.
Oct 03, 2013 | Husqvarna 155bt Gas Backpack Leaf Blower
Broken recoil starter rope on John Deere 5E Backpack blower. Is there an on line tech diagram showing assembly?
No, there isn't.
You have to take it apart, and make sure the spring doesn't get loose, or you'll have to rewind it. There's probably enough to just re-knot it if you're real lucky. Would it be for sale?
Mar 14, 2010 | Garden
thats what it is try opening the gas lid look inside to see where the fuel line lies if its up high them try pushing it down to the bottom
Nov 13, 2009 | Homelite Consumer Products Backpack...
Need to siphon gas from gas tank of a John Deere
Go to the store and buy a siphon you would use for a kerosene heater.
You can get the fuel out with this item. When you fill it back up add some "Seafoam" fuel additive. It will help keeps it running better.
Good Day.
Oct 12, 2009 | John Deere Garden
Manual for john deere leaf blower
you have to order the Manuel from john deer or a john deer dealer
What is the mix ratio for the troybilt 25cc blower?
Troy-Bilt products now are usually produced by Mtd, the ratio being 40:1.
However since John Deere made yours I'm 99.9% sure it should by 32:1.
In any case any power equipment you own (including Dolmar or Stihl) that takes an oill/gas mix benefits in the long run from using the richer 32:1 ratio. It protects the piston and cylinder much better, giving your equipment longer life. Do not use the "one mix for all" that you find at retail stores as it has been my experience it really isn't "one mix for all". Seen a lot of scratched pistons and broken rings from people using that.
Jun 17, 2009 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Water in gas tank
It's condensation if you haven't got a leek if you leave the tank full of fuel this should not happen we had this problem for years with combine harvesters and leaving them full and not empty cured the problem
Dec 25, 2008 | Destineer John Deere American Builder w/...
Garden Logo
333 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
