Bluestacks required high graphic memory or graphic card. If you already
having high inbuilt graphic memory then their is no need to worry
about that. It's minimum required Windows XP SP3 or Higher OS
version.
Steps To Use Whatsapp On PC or Laptop
- After Downloading Bluestacks install it in your PC or Laptop.
- After
the successful Installation open your Bluestacks then you will see a
Search bar in center or small icon at top side corner for it.
- Then Simply Type Whatsapp in the Search box and download it.
- If you already have .apk extension file for Whatsapp then their no need to download simply open that file with Bluestacks.
Now Install And Activate Your Whatsapp
- After Successfully Download. Now start Installing Whatsapp on your PC or laptop. Installation Required some verification.
- After Installing Whatsapp, then it will ask you to enter your Mobile number for which you want to use your Whatsapp.
Then you need to verify you mobile number by sms or call as same procedure which we done to install Whatsapp on Mobile.
- Then Enter the verification code. Now your Whatsapp is Activated and ready to use on your PC or Laptop.
- Now Simple check your contact list or add contacts manually who are all ready using Whatsapp.
- Now enjoy Chatting and Sharing
