Motor is humming but not spinning
Hi I've a maytag performa, the motor is humming but is not spinning, it's got a capacitor could be faulty, what do u think
    Champion:
  • 219 Answers
No odds are if your lidswitch is fine your transmisson is locked up trans quite expensive
Posted on Apr 19, 2009
Hi, the spin cycle on our bosch wfk 2401 suddenly stopped working. The wash and rinse cycle works but when it's time for the spin cycle to begin, the machine hums as though the motor is straining...
If there is motor humming while the spin cycle is ON , please confirm if the motor also heats up-- take caution not to touch live points. Also if you manually push the motor with care so see if the spin starts up then the capacitor (this assists with the starting) can be weak or faulty.
Remove and check with a mains tests and see if the charge retains, if not change. Other wise check if there is friction on the motor or drive.
Jun 14, 2011 | Bosch WFK 2401
My samsung wa75b7pt does not wash just hums
Possible that the motor is jammed as the motor is faulty or the main spindle drive is jammed. If so release using a de-greasing spray , manually turn to see if the shaft is moving freely. if not remove and reset.
Also the failure of the motor capacitor can cause the motor to hum. replace and check.
Apr 01, 2011 | Washing Machines
Performa washer hums--stopped mid cycle, wont pump or agitate
Hi
Thanks for using FixYa. You are right the issue is with the motor; don’t think it’s related to a capacitor. The hum sound that you hear is from the motor which is trying to run however is unable to so you’ll need to check the pump and motor and replace the part that has gone bad. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 19, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Runs fine untill it gets to the spin cycle then it hums like a burnt out motor
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Maytag Performa PAV2200
My Maytag Performa Washer is making a scratching noise during the spin cycle. Any ideas what it could be?
The problem could be due to few things.
1.There is a seal underneath the nut that holds the air bell housing on.
2.A faulty agitator component,there is a plastic hub that connects the
agitator to the motor and this can become worn.
3.Finally it can be the transmission,this is most likely your problem.
Apr 11, 2010 | Maytag Performa PAV2200
Washing machine make humming sound in control panel
change the start capacitor located at by the motor or at the back of the unit
Jun 17, 2009 | Maytag Performa PAV2200
Machine will not agitate or spin. Have replaced broken drive belt but machine only washed one load and now the motor just hums
hello it sounds like you have a frozen motor have you tryed spinning the pully by hand to see if you can spin the motor ? if your able to spin the motor pully by hand and it still is'nt turning when powerd on then your have a bad motor
Apr 05, 2009 | Maytag Performa PAV3200
Dryer motor will not spin..motor sounds like it is sutck.
Get a putty knife, release the top by pressing the springclips between the front and top.
Then remove the front. The blower wheel may be the problem. They get loose.
Jan 04, 2009 | Maytag Performa PAV2200
Maytag Performa PAV1000AWW top load washer
Try to replace the capacitor. Good luck
Jun 12, 2007 | Maytag Performa PAV2200
Washing Machines Logo
151 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
