I need assistance. My cruzer mini 256 will not open. When the disk is inserted in to my laptop or pc, the drive does not appear for selection.
  • 3 Answers
It may be corrupted. This only happens if you have been ejecting it the wrong way. Or it may not be installed right. Try going to Control Panel Add New Hardware and let the computer search for it. If it still doesn't find it, try hooking it up in another USB port on your computer. If it still doesn't work...it may be corrupted and unusable.
Posted on Apr 19, 2009
When i insert my USB flash drive called sanDisk cruzer 8GB in the laptop,am told that i need to format the disk in drive G before i can use it,when i try to format it, it says that windows was unable
If there is any Media Error not possible to format the drive otherwise use the following method on Windows 7
Open a Administrator command Prompt and type the command one by one
1.list disk
you can find the avilable disk and note your USB Drive Disk Number
2.select disk 1 (change the number)
3.clean
4.create partition primary
5.format fs=ntfs quick
6.assign
if no problem in usb it will format your USB Drive
Apr 03, 2014 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
When I insert the USB it reads error 23. How do I solve this
  1. Copied all the files that came with the Sandisk device to another location (in case I need them again)
  2. Copied all the music I had put on the Sandisk since I got it to another location
  3. Using a Windows PC, I right clicked on the drive in Windows Explorer and selected "format"
  4. I re-formatted the cruzer mini to FAT 32, default size (yes, I know it was FAT 32 already)
  5. Copied the music back to the cruzer mini
  6. Plugged it into my radio and it works GREAT! instant access to any track
Before you do this: Reformatting the drive also gets rid of the software that makes the cruzer mini copy files super fast. It will take a lot longer to copy music to the drive
Dec 16, 2009 | Vehicle Parts & Accessories
PC is not detecting my Cruzer micro pendrive but
I have experienced this type of problem before. But what I did was to install an Avira Anti-virus on a system using windows xp and eventually it did open.
So you can try it as well or insert your flash into any another system that had a strong anti-virus which can enable you scan/format the drive.
Best of Luck
Nov 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cruzer micro 4gb will not format. Also, PC will not reveal contents.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 12, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I accidently deleted the partition with my cruzer
Ok turn on PC, and have that drive plugged into the usb port. Find your my computer icon, right click on it and goto manage in the menu. This will open the computer manager, in the list on the left you will see disk manager under Storage. Click on disk management, in the window on the right you will see the different Hard Drives and Storage devices there. Look for the one that does not have a drive letter and may state unknown. Right Click on the device and Mark Partiton as active, then also format the drive. Viola! you should now have your Pen Drive showing up under my computer.
Oct 04, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do i format a san disk cruzer 2 gb ?
insert drive into usb then when it appears in sys as removable drive right-click it and select format, then FAT32 system, other options on default
Sep 23, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk cruzer micro
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Oct 24, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do you use sandisk cruzer mini 256mb
your problem is how to use pen drive
PEN DRIVE WITH DATA CAN BE INSERTED INTO AVAILABLE TYPE OF USB PORTS ON YOUR COMPUTER .
THE SYMBOL OF THE PEN DRIVE APPEARS ON YOUR MY COMPUTERB WINDOW .RGT CLICK .OPEN.Product Description
The Sandisk Cruzer Mini is a truly portable, truly useful pocket size data storage device that happens to look cool as well. Its stylish, diminutive design can be slipped into a pocket or purse for easy transport or data files, image files, video and audio, between home or office and virtually anywhere else. Fully compatible with Windows 98SE, ME, 2000, XP and Mac OS 9.1+, OS X v.10.1.2+
Oct 01, 2008 | Computers & Internet
SAN DISK PEN DRIVE troubleshooting
When i connect the pendrive into the USB drive the indicator light doesnt glow on pendrive and no "new hardware found" message appears on the screen.
Mar 18, 2008 | SanDisk Open Box 1GB Cruzer Mini...
Sandisk cruzer micro 2gb not detected
You only need to use disk management !!
for Win_XP:
Right click 'My Computer'.
Choose 'Manage'
In the left pane, under 'Storage', Choose: 'Disk Management'.
When device is connected it will appear as: 'Disk xx - Removable'.
It should be not allocated (Black Line), so you only need to created a new partition and format it.
Good Luck !! :-)
Nov 02, 2007 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
