Question about Thetford Norcold RV Cooler/Freezer
Brand new 7/2013 Norcold model n300x does not work in any mode gas or ac. No ammonia smell. Gas pilot is on and stays lit. 110 vac to plug outlet reads constant for ac mode. Thermometer in freezer unit for three days still reads 65 degrees (outside temp). Now what?
  • David Spradling
    David Spradling Dec 16, 2017
    on back board see if fuses ok and fusible link if ok disconnect thermistor if gets cold bad thermister
ronaldo_ross
  • 1056 Answers
SOURCE: Describe your Thetford Norcold® Model DE0061
Is there a switch so you can switch the unit to operate on ac? There might be, and it is switched to operate on dc right now.
Posted on Jun 28, 2009
  • 46 Answers
SOURCE: Norcold mod 1200 does not cool well in Az. during the summer time
air circulaton over the cooling unit on norcold is critical get out you owners manuakl look up baffels and make sure all are in tact and also no animals have made a home behind you refer you have done all you can do inside the problem lies on the outside of the refer where the cooling unit is
Posted on Aug 01, 2009
  • 15 Answers
SOURCE: norcold refrigerator burner will not stay lit
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
Posted on Jan 29, 2010
  • 15 Answers
SOURCE: Norcold Model 682 problem
no these units run on 12 volt aswell check your fuses or and be sure u are getting atleast 10.5 volts to that fuse
  • 332 Answers
SOURCE: My Norcold Fridge will not operate on AC
Check you 110 volt breaker in the converter panel to see if it is tripped
Posted on Mar 15, 2010
I have a 1991 Norcold 400 series 2 way fridge that works perfectly on AC but won't light on propane.
Clean the spark electrode gap may be to big for spark to jump across to light pilot You will smell gas that fast as it is coming out of the pilot .
Jun 22, 2017 | Grilling
I shut down the fridge. Not getting any power to it now. I have checked breakers and fuses. There is power to 110 outlet where it plugs in. No power to gas valve. What do you think the problem is?
Your Norcold refrigerator is powered by 12V DC, not 110V AC. You need to check input power at the power board. If the fuses are good and you have good 12V to the refrigerator, check to see if you are getting 12V past the 5amp fuse on the board. If not, you may have a bad board. Norcold Power Circuit Boards for Sale The Norcold Guy
Jul 12, 2015 | Norcold Inc Norcold 1210IM Refrigerator
The pilot light is not on how do I switch it back on?
Turn the gas valve off all the way, make sure you don't smell gas and wait an hour or so. The gas valve should have an on setting and a pilot light setting. Turn the gas valve to pilot light and you should be able to push the vlv button down. At this time hold a flame to the pilot light outlet. It should light and when it does keep holding the vlv down for about 15-30 seconds. IF you let off of the vlv and the pilot light goes out, you may have a faulty sensor. IF it stays lit when you let off the vlv. back your face away from the unit and turn the valve to the on position. Operate the cooker as usual making sure that the burner does indeed light when called for. If the pilot light will not stay lit, make sure the sensor is enveloped in the flame. If the flame is too small you may have to change or clean the pilot flame outlet. To replace the sensor, remove it from the mount by the pilot outlet(once it has cooled) then follow it back to the control valve and remove it useing a line wrench. YOu should be able to get one at the nearest hardware store.
Aug 23, 2012 | Cars & Trucks
My Norcold N611 frig code flashes 3 time every few second and doesn't go into A/C mode and will only go into gas mode when the switch is in auto mode and the interior light stays on even when the
The N611 will flash 3 times as an AC heater fault. If your AC heaters are ohming out properly (48 ohms of resistance), then you have a bad power board. If the AC heaters are not showing around 48 ohms of resistance, replace the AC heater. It's going to be one of the two. Here is an article on it:
Norcold Fault Codes AC HE or On light flashing 3 times What to do
Aug 16, 2012 | Refrigerators
Pilot light won't stay lit on new water heater
1) Get more air to the water heater and see if problem continues.
2) Read the following pdf-s for things that might apply to your situation.
http://waterheatertimer.org/images/Negative-pressure.jpg
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
3) Read pdfs above first, and then Add a comment with missing information below, for possible do-it-yourself help.
Does this water heater have a blower?
Is gas valve electronic? Or does gas valve have a dial?
If gas valve is electronic, have you checked outlet with circuit analyzer?
Did pilot light work correctly for a while? If so how long?
Where is water heater located? Hot attic? Closet? Garage? Is area dirty and dusty? Has air intake been cleaned?
What color is pilot flame? Clear blue or yellow-or-orange?
Have you inspected inside of combustion chamber for dripping water?
Aug 28, 2011 | American Standard 40 G Natural Gas Water...
I have a Norcold n300 3 way it works on 110 but
try blowing through the gas orifice with compressed air only.
Jul 08, 2010 | Thetford Norcold DE0051 Refrigerator
Norcold refrigerator burner will not stay lit. Ignitor lights the gas, but as soon as it the ignitor stops, the flame goes out. Thanks.
Nov 16, 2009 | Thetford Norcold RV Cooler/Freezer
My magic chef kitchen range oven won't turn on, no gas
Some of the models require you to push in the oven thermostat knob to set the pilot if it blows out. So try pushing in the knob and hold it while lighting the pilot. When the pilot lights continue to hold the knob in for about a minute. When you let go of the knob the pilot should stay lit. If it does not stay lit then try it one more time. If it continues to go out the thermocouple or aso might be bad and will need service.
Sep 11, 2009 | Magic Chef 31000 Gas Kitchen Range
Pilot light keeps going out on one side of my Tappan stove (TPF303BWA). The 2 left burners are fine but the right side burners will not stay lit. I can light them with a match and they stay on for...
HI, Try using a needle to clean out the pilot orfice. Most models have an adjustment for the pilot light. It would be located near the manifold under the top panel.
I hope this helps you. Please let me knwo if I can assist you further.
Vic
Jun 05, 2009 | Tappan TGF303BW Gas Range
Thetford Norcold RV Cooler/Freezer Logo
61 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
