Question about Kitchen Ranges
Burners will not light
My burners will not work on my hotpoint xl144 range they only click and i have to use a match to light them
fridgetech
  • 473 Answers
SOURCE: ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Posted on Oct 22, 2007
hotuna
  • 288 Answers
SOURCE: Viking Range
The clicking is the electrode arcing. when the burner lights, a sensor tells the electrode to stop sparking after is heats up a little, that's why is clicks a little after the burner lights, but then stops. If the spark keeps going, the sensor is not registering the flame. The ones that do not click could be the ignite coil, the wire, or the electrode.
Posted on Nov 15, 2007
freetek
  • 5568 Answers
SOURCE: Oven and broiler will not light.
You've probably done this by now since your message is May (makes us a May-December couple??) but wanted to write that the transformer that produces the park for ignition has failed.  I don't know how accessible it is in your unit, if you check on Sears website under Parts with your model # in hand, they could well have an illustrated breakdown of your range which would give you an idea of how difficult the replacement might be.
Posted on Dec 28, 2008
  • 10865 Answers
SOURCE: viking range burners won't light
All of these ranges have a spark module at each burner sight and they all click when ever you attempt to light one burner. Therefore, it can not be assummed that the spark module for those nonworking burners are actually clicking. Remove the burner covers and actually look for the sparks. If there is no spark make sure the connections are nice and tight. IF they are, you most likely need to replace the spark module.
Posted on Apr 30, 2009
  • 832 Answers
SOURCE: Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Posted on Sep 23, 2009
Spontaniously starting of hotpoint oven.
Most likely the thermostat or if electronic control, one of the relays on the control is shorting. got a model number to go along with the brand Hotpoint? Help us help you... Eric Campion
May 19, 2012 | Hotpoint RGB745 Gas Kitchen Range
Burners slow to ignite
you may have your gass set to low or you need a new regulator valve
Apr 05, 2012 | Hotpoint Kitchen Ranges
My hotpoint. Has burner activity. The electronic oven will not light, makes no sound when the temp knob is depressed, nor with a match under the burner will it light. Makes no sound through trying each...
Ok
Is your igniter glowing when oven turned on.Look for bright orange glow near burner.If yes ,and no ignition,then igniter is weak and needs replacing.No glow at all,then a voltage test at the igniter needs to be done to see if it might be thermostat problem. Very common for igniters to go.Most likely cause.
Was this helpful?
Aug 18, 2011 | Hotpoint RGB745 Gas Kitchen Range
Front burner will not light the igniter is good it woks in the other burner and i put a good igniter in the burner and it will not work
What happens when you use a long match or a long butane lighter? Does the gas ignite?
Since the igniter is working in another burner, then either the gas isn't getting to the burner (sealed burner blocked), the spark is being blocked or the electrical connection to the igniter is bad.
Take apart the burner and clean the openings. Make sure that the hole in the part that slides over the electrode is clear (use a needle or the wire from a twist-tie). See page 28 of the manual. (available online from http://www.geappliances.com/service_and_support/literature/ . Enter the model and click submit). Make sure you replace the parts of the burner correctly.
My range also has an orifice at each burner that could be blocked. Turn off the gas before investigating this. Look at the instructions for converting the range from NG to LP - this should be attached to the back of the range near the regulator. This will tell you how to access the orifice and what size wrench to use. I believe my range uses 10 mm.
To check the wiring, you may need to lift the cook top. Often the top is secured with clips on the left and right sides.
I hope this helps.
Jun 25, 2011 | Hotpoint RGB745 Gas Kitchen Range
Gas oven Hotpoint RGA 720 I can't light the oven pilot
There is likely some kind of gas line blockage or valve problem. This is not a do-it-yourself fix. Call a repair person.
Oct 15, 2009 | General Electric Hotpoint® RGA720PKWH Gas...
Hotpoint electic stove, the burners and the oven not working
Is there any sign of life? Does the oven light come on or does the clock work? Just for kicks, go and reset the breaker - it should be a double breaker for a 220V appliance - sometimes half will throw and still leave 110v that will run the light / clock.
Jul 26, 2009 | Hotpoint RB757 Electric Kitchen Range
Top right burner on hotpoint gas range doesn't light
there is a spark ignition in the middle between the front and back burners....one for the left side and one on the right side. When it was cleaned i bet that the spark ignitor was slightly bent towards the front burner...now the gap is too big to fire the rear burner...the ignitor is very similar as the spark made in those push down lighters. so its safe to play around and adjust them as needed to make them work...Go ahead and take it apart and tinker with adjusting it...until you get both front and rear burners running again the way it was before.( peek at the otherside as a reference and try to make it match)
I hope this helps you out a little bit 8-)
Jun 06, 2009 | Hotpoint RGB745 Gas Kitchen Range
The three burners on the top of the range will not light.
You either have an issue with gas flow from the control valves or with the piezoelectric gas igniters. Turn the knob to low and try lighting the burners by hand. If they work, then your problem is not gas flow but the ignition. Turn the knobs to light and see if each burner clicks and you see sparks at the igniters. If you are not seeing a spark, try cleaning up the igniter tips. If that doesn't do it, it is probably time to call the service technician (or the Hotpoint Customer Service hotline).
Mar 03, 2009 | Hotpoint RGB745 Gas Kitchen Range
Ge spectra xl44 stove
Oct 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Hotpoint RGB745 Burner Problems- Unique, needs help
Not sure, but sounds like you may have a gas pressure problem or the stove is set-up for the wrong type of gas.
Apr 25, 2007 | Hotpoint RGB745 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
