Question about Lisle Pneumatic Oxygen Sensor Remover 43900
Replacing Oxygen sensor on 2004 Hyundai Elantra VE 2.0L
I have a 2004 Hyundia Elantra. The original sensor has 5 wires (Blue, black, white, yellow and gray). Bosch universal replacement sensor (before catalytic converter) has 4 wires (black for signal; white (2) for heater and gray for ground).
Can this work and if so how....
  • 3,600 Answers
Yes it will work it is a uiversal 02 sensor place the black and gray wires together and connect to one black wire connect the white to white and the yellow to white this has a heated 02 sensor so twist them together to make sure it's right before you crip them together. the 02 sensor has a signal wire that is black and a heated wire that is black the two white wires are ground hope this helps and if you need more help post back here. the car only needs the heated part to warm it up faster to go into closed loop and the other white and black wire is the signal from the sensor telling the computer how much voltage you are getting from the 02 sensor.
Posted on Oct 06, 2009
  • Bruce Hathcock Oct 09, 2009
    just checking up on you did you get it hooked up right?
  • ImNoMechanic Jun 14, 2011
    what about the blue wire on the factory sensor?
I would like to install a Pioneer DEH-P3800MP stereo system in it and don't know which wires connect to the stereo!
2000 Hyundai Elantra Stereo Wiring Constant 12V+ Light Green Switched 12V+ Brown Ground Black Illumination Dark Green/White Dimmer Dark Green/Black Antenna Left Rear Front Speakers 5 1/4" Doors Left Front (+) Green/Red Left Front (-) Light Green/White Right Front (+) Red/Blue Right Front (-) Light Green/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Yellow/White Left Rear (-) Yellow/Blue Right Rear (+) Green Right Rear (-) Green/Blue
Jun 22, 2011 | 2000 Hyundai Elantra
I need a wiring diagram for this car my engine just stalled on me and i cant figure out the problem its not getting spark
2000 Hyundai Elantra Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Light Green
Car Radio Ignition Switched 12V+ Wire: Brown
Car Radio Ground Wire: Black
Car Stereo Illumination Wire: Dark Green/White
Car Stereo Dimmer Wire: Dark Green/Black
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4? Speakers
Front Speakers Location: Doors
Left Front Speaker Wire (+): Green/Red
Left Front Speaker Wire (-): Light Green/White
Right Front Speaker Wire (+): Red/Blue
Right Front Speaker Wire (-): Light Green/Black
Rear Speakers Size: 6? x 9? Speakers
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Yellow/White
Left Rear Speaker Wire (-): Yellow/Blue
Right Rear Speaker Wire (+): Green
Right Rear Speaker Wire (-): Green/Blue
May 02, 2011 | 2000 Hyundai Elantra
2004 hyundai elantra speaker wires not color coded with new stereo
http://www.modifiedlife.com/car-stereo-radio-wiring-diagram-2004-hyundai-elantra/
thats your cars wiring diagram
and the standard radio diagram is
yellow 12v battery
red 12v accessory
black earth
blue/white amp rem
blue power antenna
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
that should help u
Aug 12, 2010 | Car Audio & Video
2004 hyundai elantra oxygen sensor
Your Elantra has more than one oxygen sensor. There is a pre-catalyst sensor and a post-catalyst sensor. Both can be found on the exhaust. You simply disconnect the sensor wire and remove the sensor plug with the proper size deep socket. Be sure you have the correct sensor for replacement.
Because of the heat involved with the exhaust, make sure the engine is cool before attempting to remove and replace the sensors. They may be tough to remove so a shot of WD-40 or 5-56 spray may need to soak into the threads to ease removal. When you replace the new sensors, a coating of anti-seize will be helpful for future removal.
Keep in mind that one malfunctioning sensor can send information that will set off codes on other sensors "downstream" or send codes from other emission controls on the engine.
Mar 27, 2010 | 2004 Hyundai Elantra
I am trying to install a after market cd player and i need to know what all the wires from the car radio go to. thank you
1998 Hyundai Elantra Car Stereo Radio Wiring Diagram
Front Speakers Size: 5 1/4′
Rear Speakers Size: 6′ x 9′
Please rate my help.
Dec 25, 2009 | 1998 Hyundai Elantra
Replacing 2004 Hyundia Elantra O2 Sensor
Had the same problem You need to go to dealer and order an O2 sensor with California emissions. The wire will be longer and fit into the prong
Apr 19, 2009 | 2004 Hyundai Elantra
Camshaft postioning sensor
On 1995 and later models the CKP is located at the rear of the engine near the transaxle bell housing.
Sep 30, 2008 | 2004 Hyundai Elantra
Radio wiring info
Battery LIGHT GREEN (+) RADIO HARNESS
Accesory BROWN (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination DARK GREEN/WHITE (+) RADIO HARNESS
Dimmer DARK GREEN/BLACK (+) RADIO HARNESS
LF Speaker (+) GREEN/RED
LF Speaker (-) LIGHT GREEN/WHITE
RF Speaker (+) RED/BLUE
RF Speaker (-) LIGHT GREEN/BLACK
LR Speaker (+) YELLOW/WHITE
LR Speaker (-) YELLOW/BLUE
RR Speaker (+) GREEN
RR Speaker (-) GREEN/BLUE
Radio Security YES
Sep 12, 2008 | Hyundai Motor 1996 Elantra
Stereo wiring diagram
Jul 29, 2008 | Hyundai Elantra Cars & Trucks
Lisle Pneumatic Oxygen Sensor Remover 43900 Logo
2,715 people viewed this question
Top Lisle Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Lisle Air Tool and Compressor Expert? Answer questions, earn points and help others
