Red roller part number
I have a brother 7820n printer, my copies are coming with a line...i have change the drum 3 times and the same thing happen, looking at the back of the printer there are 2 rolls one is red and the other is black/gray..on the black/gray roll there is a line that i believe it coincides with the line i see on the paper..how do i clean this or how do i repalce this roll?
    President:
  • 1,126 Answers
That is most likely the upper fusing roller with the line on it. I don't know if it is possible to just replace the roller. The source that I use only offers the complete unit (2 choices) one has a white connector, the other has a grey connector.
Posted on Jun 07, 2009
We have an MFC 7820N Printer that is printing a dark vertical line down the right side of the paper only when we fax or make copies through the top tray. Please help we have replaced drums, toner,...
usually this happens because of the toner. But since you replaced that try looking at the rollers below the toner. Take out the toner cartridge and look at the rollers. sometimes ink can try on them and cause a strip on the paper. Use some rubbing alcohol on a paper towel and clean them.
Also you can go into the printer settings and do a "clean paper path" this will require you to run a piece of paper the printer will print out to try and "self clean."
Here is a link to the Brother website for the Manuel.
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc7820n_all&dlid=&flang=English&type2=-1
May 05, 2011 | Office Equipment & Supplies
Prints a black streak whether I copy, or print, not dirty glass on Brother 7820N
Try cleaning the corona wire of the drum unit.
You need to open the front cover of the machine and remove the cartridge (drum and toner) On the top right there is a tab that you need to slide from left to right about 20 times, then bring back to home position
Apr 10, 2010 | Brother MFC-7820N Laser Printer
Brother MFC 7820N Printed paper has toner ink layered on paper
you can remove the toner and drum from the machine, slide the tab back and forth about 20 times then blow in the slot. when you put it back in the machine if the problem keeps happening it would be a problem with the toner cartridge and it would need to be replaced
the reason this happens to toner cartridges is because the rubber roller tarts to wear out.
Mar 05, 2010 | Brother MFC-7820N All-In-One Laser Printer
I have a 7820N. I put in a new drum in January and have printed a few hundred pages. Put in a new toner cartridge after i started getting lines and streaks on the paper. They come and go but are getting...
Hi There,
When you installed your new drum did you reset the drum by.
1 - Opening the front cover.
2 - Press the options button up on the panel.
3 - Press 1 to reset
4 - Close the front cover done.
If the issue persists after resetting your drum contact brother technical support you may have a defective drum unit.
Thanks,
Viper1969
Mar 03, 2010 | Brother MFC-7820N All-In-One Laser Printer
Getting horizontal red streaks across printed page
The drum roller is damaged. You must be careful and spin the cylinder. do not touch the roller. You probably have a line in the roller that causes this issue. Each time i have seen this problem, this was the cause.
Feb 12, 2010 | Brother MFC-9840CDW Laser Printer
"Change drum soon mean" in my 7820n?
drum and cartridge are two different things. The cartridge is attached to the drum. They do need to either be cleaned with rubbing alcohol and cotton swab. You can try to clean out the connections. But many o require replacement.
Jul 02, 2009 | Brother Office Equipment & Supplies
BROTHER MFC 7820N MACHINE PUT IN NEW DRUM, CHANGE DRUM MESSAGE COMES ON. PUT IN NEW TONER, TONER END OF LIFE MESSAGE COMES ON.
To manually reset the counters, do the following:
  • Open front cover, press "option".
  • Answer Yes (by pressing 1) to the question in the display.
  • Your drum counter is now reseted. Press "option" again.
  • This time, press *, 0, 0.
  • Your toner counter is now reseted too.
(If nothing happens when pressing option, try using the back/clear button instead.)
Jun 15, 2009 | Brother DCP-7020 All-In-One Laser Printer
Brother 7820N, printing image repeats?
have you tried changing the drum unit for a brother oem unoit and oem toner? generic toner and drum will always mess the machine up!!!!!!! good luck brother sr tech
Dec 22, 2008 | Brother MFC-7820N Printer
48 people viewed this question
k24674
jasbo
jasbo
