Question about Microsoft Xbox 360 Elite Console
Installing windows xp
Hello, on one of my comps the disk drive is a bit dodgey and was wondering is it possible if i wipe the hard drive using f disk then could i use an external disk drive to install windows using the disk? if so could you tell me how i could go about doing this thanks.
  • Matt Marley Sep 18, 2007
    Posted in wrong section could some one move it thanks.
    Problem Solver:
  • 6 Answers
I assume you are talking about the optical drive being a bit dodgey.
Just purchase an external optical drive and set your BIOS to boot from USB. First, check to make sure your computer supports that. If not, then just replace the drive?
Posted on Jan 05, 2008
SOURCE:
Windows can't find any hard drives...when installing xp
It sounds possible that your Windows XP install CD does not contain the necessary hard disk device drivers for the drive used in your Dell Vostro laptop and you would need to load these drivers separately during the XP install when the option is given to use third-party device drivers.
Some laptops may provide options in their BIOS settings to use a compatibility mode of operation for newer SATA hard drives that will make them visible to bootable utilities such as disk imaging software and older OS install CD's.
Jan 01, 2012 | Dell Vostro 1510 Laptop
I have the same problem the toshiba recovery disk i get error message 10f8060017.its a toshiba A105-2194 win xp media edition. i have tried everything wiped the disk to all 0's. Used a win xp original disc...
You have tried all possible solutions and troubleshooting.
My Suggestion is to check the Warranty of the Hard Disk and get it replaced. this possible shows a mismatch between the Laptop and hard drive.
Feb 15, 2011 | Toshiba Satellite A105 Notebook
How can i partition my 320gb sea gate ext harddisk
you can partition your hard disk while installing windows xp
and if you want to parition your hard disk after installing your windows,you will need third party softwares called parition magic which are free to try,but you will have to buy those softwares to use it,so its better to paritiyion your hard disk while installing windows
Jul 22, 2010 | Seagate 320GB FreeAgent Pro FireWire 400,...
Help me in formatting my hard disk
Put OS disk in shut off computer
restart computer
push ENTER to boot from cd- this is not happening.
It is possible that your OS disk isn't good
Apr 12, 2010 | Dell Dimension 2400 PC Desktop
Want to comp re format hard drive and then install
well if u have windows 7 disc, then u can use that to boot the computer from the disc n then it will give u option to format the hard drive and install the new os.
u will have to boot the computer from the windows 7 bootable disc.
Nov 01, 2009 | Dell Optiplex 740 Desktop Desktop Computer...
My computer running xp doesnt see my old comps drives that ran 98
hey man try to install windows xp to solve this problem if this problem is not solved then it should be ur hard disk is higher than the compatible default rate which is may be 30 or 20 GB
Jun 20, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Problem while installing Win XP Prof.
The prolem is with Windows Xp cd...
When i try to install through the Genuine Win XP cd then it works fine...
Ok...
So use the original softwares....
Feb 16, 2009 | Intel DG31PR Motherboard
Downgrade from Vista to WinXP Pro
No, you need to go into your computer's BIOS and set the ahcp mode to IDE. Then windows xp will see it just fine.
Please take a moment to rate as fixya. Thanks!
Feb 06, 2009 | Acer Extensa 4620 Notebook
Pc is dead !!
you need window xp disc to boot from and install.You could borrow from a friend. you will also need the serial code.
Oct 05, 2008 | Computers & Internet
Installing windows
1. Windows 2000 / XP maximum hard drive size 137 gigabyte limit
This one was fun. To install a hard drive larger than 137 gigabytes on your computer you need the following:
a motherboard, such as the Gigabyte GA-7N400 Pro2 which support the 48 bit hard drive addressing. Only new motherboards can be counted on to support this.
Windows 2000 service pack 3 or later. Windows XP service pack 1 and greater have this support built in. I assume this isn't a problem with Linux at all...
Shalom
Aug 25, 2008 | Maxtor Hard Drive
Microsoft Xbox 360 Elite Console Logo
100 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
