Question about GE Dryers
My dryer runs but does not get hot what is wrong?
It is a general electric dryer
  • blklucyga Apr 19, 2009
    what could be wrong with my dryer
  • 77 Answers
First thing would be to consider is your element. IF you have a meter, you should turn power off to machine and check continuity or ohms across the element. If it is good you should then check the thermal fuse. It looks like a white disk with a small fuse inside. On both of these you should remove wires before checking them. If they are good, there is an overload on the housing of the element. Sometimes they are resetable with a button in the middle, most are not. Check it the same way. Now you did not say if it was heating a little. But if it is, then you probably have a blockage or kink in your vent. Also check outside to make sure that the flap is not blocked. Good luck.
Posted on Apr 19, 2009
5 Suggested Answers
  • 36 Answers
SOURCE: electric kenmore dryer #60702 is running too hot
the coil should glow visually through the of coil casing. if you reinstalled the rear panel,then watch the coil for the first 15 minutes to see if it still glows the whole time. if it does replace the snapstat sensor on the casing. also go outside and feel the heat coming out of the vent . it should be about 15 degrees cooler. the noise can be any of these; belt idler , belt , guides. ordryer not level. try these and get back to me please. thanks karl
Posted on Oct 31, 2009
  • 289 Answers
SOURCE: electric dryer is not getting hot
nead to know mod#
Posted on Dec 29, 2009
AcJim
  • 107 Answers
SOURCE: my general electric dryer, model
You more than likely have a bad heating element. This is 99% of the problems that occur in electric dryers
Posted on Aug 11, 2010
  • 273 Answers
SOURCE: General electric dryer is in
Check your lint filter and make sure that the vent duct is clean from the dryer all the way to the outside of your home.
If this checks out, the cycling (high limit) thermostat is malfunctioning or the fan and/or fan's blades are broken. None of these are very difficult or expensive to repair.
Posted on Mar 02, 2011
The dryer gets hot and then cuts off now it want even turn on I was wondering if it was the therma fuse, thermostat and the heat element that went wrong. E-mail address is mrcal32@hotmail.com
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Mar 26, 2011 | Maytag PYE2300AY Electric Dryer
Dryer runs but will not get hot
hi crich... generally when the dryer will not get hot the heating element is bad and must be replaced. Joe
Thanks for choosing Fixya!1
Feb 24, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer runs but doesnt get hot
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 23, 2011 | Maytag PYE2300AY Electric Dryer
I dont know if this is the exact dryer I have or not but in general i have a couple of questions that need answered. 1) My dryer is no longer getting hot and drying my clothes 2) my timer never turns off...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 23, 2010 | Kenmore 62802 Electric Dryer
The everything in the dryer is running fine but the heat isnt working
heatman101
Oct 14, 2010 | General Electric DBSR463EGWW Dryer
My gas dryer all of a sudden just stopped getting hot. it runs but just does not get hot.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 02, 2010 | Whirlpool WGD5600S Dryer
KEEPS SHUTING DOWN AFTERYOU START IT
check the igniter, maybe it is not hot enough anymore. it needs to glow white not orange. if it is orange change it.
Oct 24, 2009 | General Electric DWSR463GGWW Gas Dryer
No heat dryer
heatman101
Apr 07, 2009 | General Electric DBXR463EG Dryer
Maytag dryer not blowing hot air (2yrs old)
If the vent is blocked, it will not stop the heat, it will only restrict the air flow.
Generally a couple of things can cause the heat to stop.
Either the thermostat or the element.
I would first suggest the element.
It may be fatigued therefore the internal wire within the element becomes fragile and eventually breaks down. Although it is an electrical item, it is mechanically built and can fail.
In some dryers the element is held in clips.
These clips can cut into the element.
The thermostat maintains temeperature but again, it is mechanically built and can also break down.
If you are not capable of inspecting or troubleshooting the internals of the dryer (i.e remove the cover and look for the failurer), then have it inspected by a repairman. There is not too much that can go wrong with a dryer. The most expensive part wuld be the motor that spins the drum.
Sep 16, 2008 | Dryers
Dryers Logo
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
