Question about Aiwa HZ-WS2000 MP3 Player
How to set the time and date on a missil pmp-8308 *gb touch screen mp4
  • dmaggrah Apr 21, 2009
    try and set time and date but returns to 1980 not sure whats going on
It was a struggle to find that out when i first got it,
-touch the clock symbol
-enter date...
-when you entered the date. Touch the calendar symbol, which is right below the " <-- "
-then it should ask you to put the time, once you entered the time click the clock symbol which is right below the ' <-- " then your done all set
Posted on May 01, 2009
After adjusting the display to the correct time...tap the calendar symbol in the upper left of the window to move to the time adjustment window. When you have that set to the correct time, tap the symbol in the corner again to finish.
Posted on May 11, 2009
Might buy Missil 8GB MP4 touch screen Any Suggestions?
Missil multimedia prpducts tend to have problems with the headphone jacks, I've had numerous MP3/MP4 players made by them, including the non-touch screen version of the one you're considering buying, and of all the ones I've had (probably around 15 different items from Missil), about 1 in 3 had issues with the headphone jack disconnecting from the circuit board inside.
That being said, a friend of mine has the touch screen one, and granted you have decent headphones, it has amazing sound quality for the price and all around is on par with anything of the iPod series, other than in reliability. Just make sure you get the longest warranty you can afford with it, just in case. When buying cheap electronics, the product itself will usually defect before it breaks from the users flaws.
Mar 14, 2010 | Generic Memory Missile Launcher
Cant get the stupid thing to be redognised by vista usb drivers for the mp3 not installed or regnoised
Hi There,               Vista should reconize  it as a usb divice and look into the storage space. Just try to use vista in the control panel and goto add new hardware if ask for driver just but in the software mini cd it came with. I have no problem with mine. If it does not work then you might have a faulty product or you should ask a vista tech how to identify a a usb divice mp4 player to windows. I know the pmp 8308 Missil is compatible with Microsoft Window Vista. It should just be plug and play and identify as a usb device so you can drag and load your videos or mp3s or pictures or even text into your ebook on the device. I hope I helped a bit. Good Luck
May 04, 2009 | Audio Players & Recorders
Missil pmp-8308 has a frozen screen
Hi There,                On the pmp 8308 Missl Mp4 there is a hole on the left side of the device. Just stick a needle into the hole to push the reset button on the inside of the device to unfreeze the device.
Apr 02, 2009 | Aiwa HZ-WS2000 MP3 Player
Computer does not see device
Turn off computer, turn on device. Restart computer. It now sees the device.
Mar 28, 2009 | Aiwa HZ-WS2000 MP3 Player
Can't set the date and time
Hi There,                For your pmp 8308 Missil 8gb Mp4 touch screen. You goto the setting icon touch screen button , then got the time setup and touch that to bring up the date window box screen. In there type in your date you need then touch the icon calendar to goto the time window box screen. Type in your time you need then touch the time clock icon. You should the see  SUCCESS pop upin a small window box. then you are done.
Mar 27, 2009 | Network Computing Devices (NSH800S/A)...
My headphones wont work everthing else is fine
Hi There,                The input for the head phone is a 32 ohm input. You need to get the proper 32ohm headphone for it. It seems that you tryed others but there are 16 ohms and 32ohms headphones. But if they do not work then it is your input connection or the device if your headphones work on other devices.You should bring the product back as a faulty device to the store and exchange it with your reciept then.  For the headphone that works on one side it can be the headphone jack that does not fit properly into the hole input (female jack).The one side does not touch or connect for it to work. It happens to cheap headphones and some good ones too. The male jacks on the headphones are slightly off it specification size by a small amount that it is not noticed by the naked eye, so it does not get a good connection.Try another head phone if you haven't tryed that
Mar 26, 2009 | Audio Players & Recorders
Missil Mp3 player pmp-8308
I have no Problem with mine. Just read the manual and play around with it. Mine fast forward and rewind @ 2x, 4x, 8x, 16x, and 32x time the speed. I have no problem putting in folders in the record folder with the manufactured software it cam with. I even can hold up to 12 movies on it. The Micro sd slot holds up to 8 gb making this mp4 player a 16 gb player. All I can say play around with it more. A problem is the touch screen can be too sensitive but that is a miner problem for me. I just softly touch the screen. It can pause and stop. Hold three second to make it stop. tap fast forward to go to the next videos or movie in folder. If hold for three second the fast forward or the rewind you get the time speeds each time you hold for three second. To me it is a Good Mp4 and Mp3 player for the price I paid. With the micro sd in it making it 16 gb, I can hold 12 movies, 8,000 songs, 700 pictures, and have 9 text in the ebook: This is what I have on Mine. Just learn more by playing around more with it.
Mar 21, 2009 | Aiwa HZ-WS2000 MP3 Player
Is it possible to put games onto a missil SD 2801?
No not yet.The device look like they can have more games on it but the company has not look into allowing more games or new one on there. Only I have seen is new games are on there on new products and next year products. I don't know how to contact them to make a website that we can download game from for these devices.I like summit improvement on these products because I love mine it work good for the price I got mine for.I got the Touch Screen pmp 8308 Missil Mp4 player that looks like an i nano pod for only $80 canadian dollar. It has similar feature but not quite the same But for the price you can't beat what come with it.
Dec 28, 2008 | Network Computing Devices (NSH800S/A)...
Mp4 by missile garbage
Dec 26, 2008 | Network Computing Devices (NSH800S/A)...
Aiwa HZ-WS2000 MP3 Player Logo
176 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
