Question about Canon PIXMA MP160 All-In-One InkJet Printer
Error 5100 in Canon MP160
get an error message number 5100. The alarm and a number 2 / E are blinking alternating. So is the ON/OFF button. I have follow the instructions "Cancel printing and turn off the printer. Wait a few moments, then turn the power back on. If the problem persists, contact one of the service centers.
  • 4,041 Answers
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Jan 28, 2010
Error message after cartridge refill on Canon MP160. How do you clear/ reset the printer after refilling the cartridge?
what error come out???
you can push and hold maintanace n colour button...
wait untill you see number 1..
if error 5,you catrige was broken...
too much ink...
Jun 13, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Canon MP160 error code 2 E blinking alternately; also get Service Error 5100. I cleared out a pencil from the paper feed area and replaced a loose spring, but still get 2 E error when I try to print
Press the <Black> or <Color> button to clear the error. If unsuccessful and printer is not functioning properly you may need to reset it:
1) Press and hold <On/Off> for one second. Display will go blank. (If this does not happen, unplug the printer).
2) Wait approx. 10 seconds
3) Plug in the device - Press <On/Off> if necessary to power on the printer
4) Wait until the device has finished its startup routine
If the problem still persists, your MP160 may need servicing by a qualified technician.
Dec 24, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My problem with my pixma 145 is there is an error "ink absorber i
Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Mar 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E 2 and service error 5100 on Pixma mp160 printer
You can try to clean out the printer check to see if there is any paper jammed in it somewhere
Then realighn the printer cartridges and run a test page.
Make sure that the paper tray is not overloaded
Dec 24, 2008 | Canon PIXMA MP160 All-In-One Printer
Error message on Canon MP160 flashing E-2-2 error message 5100
The error code refers to Ink Cartridge
Issue: ERROR: Error code 5100 appears on the computer screen
Issue: ERROR LED: E, 2, 2
1. Disconnect and reconnect power cord to reset the device
2. Remove Packing Material MP160 / MP180 / MP460
3. Reseat ink cartridge (MP160 / MP180 / MP460)
Nov 15, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon mp160 E2; printer won't re-set
hi dear
may the error code or how many blinking can solve your problem
this is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
try this methode
Methode 1
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
button pressing
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
Feb 16, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP 160
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-2
Feb 14, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
813 people viewed this question
old marine
old marine
