Question about HP Officejet 4315 All-in-One Printer
Our printer says it has a cartridge error and it won't print anything. We changed the printer cartridges and tried to reinstall and it still isn't working.
  • 1 more comment
  • tbmsp2909 Apr 19, 2009
    We already did and it's still not working.
    We tried that, too. Is it possible to run it without the color cartridge because I think it's the problem, but when I take it out it says that I have to put it back in.
  • jiig Apr 30, 2009
    Printer says 'cartridge error' and says refer to 'device document'. Where do I get that ? Have taken out cartridges and re entered them to no avail. J
    Sergeant:
  • HP Expert
  • 285 Answers
You'll need to replace the cartridge with a genuine new one.
Posted on Apr 19, 2009
  • Andrew Perrong Apr 19, 2009
    ok. well... try cleaning the contacts on the cartridge(s) and the printer.
Should "cleaning the print nozzles" do anything with the color cartridge?
First, make sure the cartridge isn't dry. You may have to get into the Printer Preferences and check to see if the software hasn't been changed to 'black only'.
Feb 08, 2012 | Lexmark X2690 All-In-One InkJet Printer
Printer cartridge alignment checks
Is this with new cartridges or refilled?
If refilled, the nozzles may have become blocked which isn't the easiest thing to clear. If new cartridges, take them back for a replacement at the store and try again with new ones
Dec 12, 2011 | HP LaserJet 1320 Printer
Caution lite flashing over cartridge of hp deskjet 940c. error message says that there is not color ink cartridge in printer. There is and the interface says the tank is full. It won't print...
Even though the interface says the cartridge is full, if the printer detects it being empty, odds are you will have to replace the color cartridge, even though you are only printing black.
You can try taking the cartridge out and cleaning the contacts with a pencil eraser and reseat the color cartridge. If no change, replace the cartridge.
Jun 30, 2011 | Computers & Internet
I am trying to print a document after changing the print cartridge and it says the printer is offline and it will not print anything.
Make sure you put right cartridge #27 or #56 for black cartridge and #22 for color cartridge.Restart printer and computer.If not help reinstall the drivers.
Nov 11, 2009 | HP Officejet 5610 All-In-One InkJet...
Not printing anything but bold black strips
you need to check if the cartridge is ok. take out the cartridge and reboot your printer. if it ask for a cartridge, turn off the printer and install the cartridge., if problem still persists, then try changing your cartridge with a new one. If problem still persists, i suggest reinstall the drivers of the printer. Pm me if your problem is solved. thank you .
Aug 07, 2009 | Lexmark X5150 All-In-One InkJet Printer
Error 50 c
  1. Power off your printer.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
Hope this helps.
  1. Lower the scanner unit until it is completely closed.
  2. If you receive the error message again, replace both cartridges.
Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
Error message "change cartridge invalid refill" the printer wont print anymore
Trying cleaning the contacts on the cartridge and clean the contacts on the printer use a dry tint paper towel to clean the contacts. Then try to reinstall the cartridge using the software. Try to print the self test. If failed try another cartridge if you dont get any error then the cartridge might be defective
Apr 27, 2009 | Office Equipment & Supplies
Canon MP F50 "wrong cartridge" error
remove all cartridges leaving printhead intact.
close cover, turn off
turn on, let power up, error message should be gone.
open cover, reinstall cartridges
if you cleaned your print head like I did you'll probly
eventually end up getting a new one anyway, due to the color variations
but I can at least print text.
Apr 08, 2009 | Canon MultiPASS F50 All-In-One InkJet...
LEXMARK X5150 CARTRIDGE ERROR
Try this --
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges
Nov 18, 2008 | Lexmark X5150 All-In-One InkJet Printer
81 people viewed this question
Ben Johnson
