I have a Philips 15" LCD HDTV with no picture, but sound. How can I get the picture back. I don't have any audio or video connected, nor do I want any connected. The Model # is 15PF5120.
  • 1 more comment
  • Suzie92234 Apr 19, 2009
    I have a Philips 15% LCD television, Model I.D. 15PF5120/28. It is NOT a projection TV. It is a small, flat screen TV. The screen is black; no picture. I do have sound, which I can adjust and I can change channels. I want the picture back. The only thing hooked up to it is the cable.
    One more time. I have a 15" Philips LCD TV, Model I.D. 15PF120/28. Not a projection TV. I have no picture. I have sound, which I can adjust, and I can change channels. I have no picture. Nothing happens when I hit "Menu" because I have no picture. I cannot accss any of the buttons on the remote because.....I have no picture. The screen is black...all the time.
    Please see my last repost regarding my Philips TV.
  • 88 Answers
Hi, I want you to first unplug your TV and unplug the cable box (if you have one) and unhook the cable from the TV, wait 2 minutes. Starting with the cable going into the TV, rehook that first. Then restart your cable box (if applicable), then plug the TV power back in. Check the "Tuner Mode" control for the correct setting. Next, run the "Auto Program" feature to find all available channels, this can take up to 10 minutes. Once done with auto-program, press the AV button on the remote control and make sure the correct signal source is selected (Should correspond exactly with source where you hooked in the cable to the TV). If you are running in PC mode, the video signal must be present or the TV will turn off. If this does not fix the problem, please respond with the name of the cable/sat provider you are using as well as if you have other TVs available for other checks, are all cables free of breaks in the cable as well as all end fittings in order. and lastly if no cable box, is the cable directly coming from the wall to the tv. Or, if we Fixed Ya! - please rate me. Thank You very much.
Posted on Apr 19, 2009
    Brigadier General:
  • 8,619 Answers
Hi
KIndly check antenna/cable connections. Are they properly secured to the TV’s ANT75ω plug? If they are then :
• Check the TUNER MODE control for the correct tuner setting.
• Try running the Auto Program feature to find all available channels.
• Press the AV button on the remote to make sure the correct signal source is selected.
• If using an accessory device, be sure that it is functioning properly.
• If in PC Mode, a video signal MUST BE present or the TV will turn off.
If this does not work then reset to the original factory settings by performing the following steps:
  1. Press the MENU button on the remote control to see the onscreen menu.
  2. Press the CURSOR DOWN button to highlight the INSTALL menu, then press CURSOR RIGHT to enter.
  3. Press the CURSOR DOWN button repeatedly to highlight the FACTORY RESET control, then press CURSOR RIGHT to enter.
  4. Press CURSOR DOWN to select “YES” to reset the original factory settings.
  5. Press the MENU button repeatedly to clear the menu from the screen.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Apr 19, 2009
    Hi
    Please click on this link and follow the instructions.
    Thanks
    Rylee
    Novelist:
  • 133 Answers
Hi Suzie,
I understand that there is no picture signal at all however when you increase the volume or adjust any other control through the front panel or through the remote controller; Do you see any indication on screen like volume bar?
Regards,
Srinivas
  • Srinivas Dhulipala
    Srinivas Dhulipala Apr 19, 2009
    oh .. my question seems to have been answered already .. it wasn't visible as i was in the editing mode.
    Thanks.
Philips 52'' hdtv 1080p while watching it looses picture but still has sound
The back light inveterate board and CCFL lamps should be checked. Check and replace the faulty component. Back light inverter can only be replaced as card basis.
Jan 30, 2013 | Philips 52 In. LCD HDTV
No picture on my philips 42PFL7422D/137 lcd I have already replaced both master and slave boards and my picture returned. After about a month or two the tv started to make a high pitch whistling sound...
do you have sound but no pix?its the video board if you have neither it will be the board where your coax and audio inputs connect...just a matter of getting the right boards off of e-bay GOD bless
Sep 18, 2017 | Philips 42PFL7422D 42 in. LCD TV
I have a memorex dvd player and a dynex 32" lcd hdtv. I have all the cord correctly in the component plugs but the picture is black and white and there is no sound.
HI,
i think ur component video connection may inter changed. check it. are u connected red to red, green to green an blue to blue. if interchanged the picture will be black and white. also check the video system of ur tv and dvd.
about audio. for that u need a stereo rca chord. connect the audio output of ur dvd to the component audio input of ur tv. if u have already connected the audio cable , check the audio setup of ur dvd. there is selection for pcm audio select it and then check again.
ok
Dec 15, 2010 | Dynex 19 in. LCD Flat-Panel HDTV
We have just recently repositioned our Philips Model No. 42PFL7422D/37 Flat Screen TV and thought we had written down the proper wiring set up for connecting to Charter Communications etc. Is there any...
CHARTER BOX
3 CABLES
YELLOW - VIDEO
RED - R. AUDIO CHANNEL
WHITE - LEFT AUDIO CHANNEL
Hook them up to tv's INPUT of the same colors
Then turn tv to input or av channel.
Mar 31, 2010 | Philips 32PF7421D 32 in. LCD HDTV
I connect a WD TV to this TV and there is no video/audio signal.
please check to see which video you connect to for example video 1 then go to source/input on remote and enter video1 . if this don"t work the TV has a picture output problem.Let tv repair guy look at it.
Aug 18, 2009 | RCA L26HD32D 26 in. LCD HDTV/DVD Combo
I Just connect My pc via 15 pin RGB cable to LG 32R50xx lcd tv,it show the picture but no sound. Than i connect the audio cable to the tv use 3.5mm j. it only has sound when I use input and select AV3 but...
You probably need a audio cable that runs from the pc audio out to the TV audio in. Radio shack has them so do a lot of hardware store and best buy.
Aug 08, 2009 | LG 42LG30 42 in. LCD HDTV
Philips 32TA2800
The Way Im understanding your problem is,
it seems like you need to hook your rcas directly to the tv and switch the surround to aux or something similar to that.
Jun 14, 2009 | Philips 32PF7421D 32 in. LCD HDTV
HDMI Connection
Yes it does, HDMI can handle more information and provide better picture and sound. Works like this, Cable-OK, Component-Even Better, HDMI and DVI-both Digital and the best sound and video. The only way to get full HD is with HDMI or DVI. Hope this helps
Jan 17, 2009 | Philips 52 In. LCD HDTV
Philips 32" lcd hdtv. HDTV no longer displays, but sound still ok
I reset the comcast cablebox. I totally unplugged the cablebox for 20 seconds and then plugged it back in. Turned on both the cablebox and the tv and the HDTV channels operated correctly.
Dec 08, 2008 | Philips 60PP9202 60" Rear Projection...
Picture goes into multi coloured vertical lines
have a tech check your tv your problem is in the video circuit could be a cold solder or a component is damaged and need to be replaced.good luck.
Apr 15, 2007 | Philips 32PF7320A 32 in. LCD Television
Televison & Video Logo
270 people viewed this question
Top Televison & Video Experts
Electro Med Services...
