Question about Brother MFC-640CW All-In-One InkJet Printer
Broken feeder arm
We had a paperjam and when we went to pull out the paper it would no longer feed anything. So i pulled off the two screws under the lid and when i hit stop to see if it would rotate or maybe it was offset a small plastic finger to which the arm attaches to the roller was just sticking in the grease. I am trying to find where to buy the new part and the proper way to remove and replace the old arm
  • aaronwallen Sep 19, 2007
    thank you very much this is a great help:)
  • 832 Answers
Buy a 2.hand dcp 110 at eBay. It has the same printengine. remove the cable and the ONE (;-)) screw on the left handside in the hole. Replace the hole printunit. Fix cable and printhead. Its cheaper and saves a lot of time!
Posted on Sep 18, 2007
SOURCE:
The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
When I try to print only one side of the paper is pulled down
Probably you have a object which blocks paper from left side on feeder.Look carefully using flashlight in the feeder.If you don't see anything the printer must be disassembled.
Nov 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
My Canon 5050 bottom drawer came out, an arm inside has popped up and we now can't close the drawer. We've can't gently put the arm back down. How can we get the arm down again?
Prior to the issue you facing basically ,you check whether u can reattach the arm or you can try to compare with another drawer to figure it out .See anything that broken or crack pieces.Kindly post pic to me ,I'll might help u.Thanks ,pls rate me!!!!
Sep 20, 2009 | Canon Office Equipment & Supplies
Epson R265 paper feed problem
Paper feeder problem. You must open case and paper feeder.Check for all screw. spring, rubber and lubrication. If you never done, find diagram at printersiam.com. is printer paper jam berfore? and clearing jam by pulling paper form back?
Jun 28, 2009 | Epson Stylus R265 InkJet Photo Printer
IBM 1422 not feeding 8 1/2 x 11 paper through multipurpose feeder
Go into the paper menu and set the multipurpose feeder paper size to letter. It will work if the paper size is set correctly for the MPF.
Apr 30, 2009 | IBM Infoprint 1422 Laser Printer
Document Feeder won't work
hello! check and look to see if there is anything blocking the paper feed area, if all is good, get some denatured alcahol and clean the paper feed roller as it may have a build up of paper dust good luck brother sr tech
Jan 14, 2009 | Brother MFC-8460N All-In-One Printer
Check Document
Look at the sensor arms on the feeder cover...open feeder,and take it off from the sides..there are little wings that pop out of socket, and look at the black toggle arms... one most likely is dislodged...make sure they all toggle freely...ckeck the one towards the bottom first...if you have to , take screws out and pull cover apart to re-insert toggle arms....
Aug 28, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Feed problem
line gear has a broken tooth on it, possibly. or you have a sliver of paper stuck under the plenum (large black roller that paper wraps around to feed). you can pop the cover off, by pulling the front edge up and away from the base (clips in only, no screws). remove the plenum with tabs that pull up on either side of it. pull out the plenum, and check for any paper under that area. good luck.
chris
Apr 18, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printer pulling on paper
My husband took the top cover off the printer and took a good look inside with a flashlight. He found a hot pink crayon stuck where the paper feeds through. I guess I should have had a better look initially, since the paper never made it all the way through the printer. Works like a charm now!!
Feb 23, 2007 | Lexmark X6150 All-In-One InkJet Printer
Brother MFC-640CW All-In-One InkJet Printer Logo
1,193 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
