Use this user manual, it will solve your problem
http://www.nodevice.com/user_manual/sony/dvd_cd/dav-dz1001.html
SOURCE: problems with hearing sound from bravia LCD tv through bravia DAV-HDX275 theatre system
The fiber optic port on back on your bravia tv is only for when your using a over the air antenna and watching local atsc channels in your local market. You need to run the fiber optic from your hd cablebox if it has one or your hd sat box if it has one. If you don't have a set top box with the fiberoptic port on it you can use a digital coax cable from the cable or sat box to sound system. The only other way to get sound if you don't have a cable or sat box is to run the red and white rca audio cable from the tv to the sound system and got to the audio setup on tv and turn the tv speakers off and you might have to adjust the audio to fixed instead of variable.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
SOURCE: Sony Bravia Dav-HDX279W and comcast HDTV Cable box connection.
Like above, use an optical connection (need fiber optic cable) or a coaxial connection (single RCA cable). HDMI might also work, but I personally haven't checked. Connect the audio outs from the cable box to the audio ins on the home theater. The TV will only need a video connection from the cable box, as well as one from the home theater (for DVDs, onscreen menus).
This discussion can help you set up the universal remote.
SOURCE: DAV-DZ260 + KDL-32V4000 - no audio from TV to DAV via HDMI
Check DAV amp menu and select DTS surround or any other digital sound option.
SOURCE: i have a sony bravia 40v3000 tv and a sony
MOst TV's have fix or variable output find this on the TV menu & set it on or variable mode or fixed output mood.
