Question about Samsung DVD-V9650 DVD/VCR Player
Samsung dvd-v9650 disc read issues
I have about 100-200 of these samsung models. 60%-70% of which are all experiencing the same issue. When a dvd is inserted it spins, but you can watch the laser slide back and forth. Almost like it gets to a point of the slider and gets stuck so it resets. It continuously does this, and never reads the dvd. Any help with how to repair the lens or if you know the common problem with this model, would be greatly appreciated.
SOURCE:
VOTIT
  • 2071 Answers
SOURCE: My dvd player Samsung DVD-R135 will not read any disc
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Sep 06, 2008
  • 98 Answers
SOURCE: player won't read a DVD
Sounds like a bad pick up assy (Laser)
Posted on Nov 25, 2008
  • 790 Answers
SOURCE: Dvd recorder can't read the disc.
Hi
Try to cleaning the pick up lens with 100% cotton.
Thanks!
Posted on Dec 05, 2008
SOURCE: Will not read blank media so that I can record.
i have this model and the problem was the speed of disc you need itcant be any faster then 2x. the 4x is to fast for it i guess. I was doing ok with the "memorex DVD-RW reritables 2x ,4.7gb,120min.
Posted on Jul 18, 2009
SOURCE: Samsung BD-P1500 will not play blu-ray discs
it seems that samsung is posting it's firm updates online @ samsung.com i had same problem with my BD-UP5000 its connected to the internet when i go to the menue to update on the bluray player it said i had the latest update went online and found a new firmware on there web site, check samsung web site
Posted on Aug 10, 2009
When disc is inserted it reads no disc
I had the same issue with my Samsung i ended up just replacing it. The laser seemed to read the disc went bad.
Apr 02, 2014 | Televison & Video
Insert disk all i get i load then it eject disk
Well it seems that your DVD player is having an issue reading the disc, I guess the first question is what kind of disc are you trying to insert? Is it a burned DVD or is it a movie dvd? This model is not a Blu Ray so if you are trying to use a Blu Ray disc then it will not read it. If you are trying to read a burned disc from someone then more then likely the disc was not finalized and is unable to recognize the disc, because the finalization process is where all the the information is written about what kind of disc it is and the format, codecs, etc. OR maybe the laser is dirty or the DVD player has kicked the bucket. Finally, the product DESC says it can read DVD-RAM, DVD-RW, DVD-R, DVD+RW, DVD+R, VHS formats, but I have found that some DVD units do not like certain brands of Blank DVDs. I hope this offers some ideas for you and good luck!
Oct 29, 2013 | Samsung DVD-VR357
Stuck in safe mode
To begin with someone needs to open and look inside the unit to see if the disc is out of position or jammed, this could trigger the safe mode.
Dec 13, 2012 | Samsung DVD-V9650 Dvd / Vcr Combo Player...
I got a new Samsung DVD player (1080) and when I put on brand new discs in it, it just kept whirring inside, but nothing came up on the screen ! I have it connected via HDMI cable to a Samsung LCD TV, so...
If a new DVD player ur tv dose recgonises the DVD disc and not reading the DVD disc,it might be dirty or scratches and cracks on the DVD disc itself.Tries It with other DVD discs,if have the same problems,than it is the DVD player itself,newly bought,yes return it get another one.
Dec 15, 2010 | Samsung DVD-H1080 DVD Player
I have a BD-P1200 that has never been upgraded, how do I do that?
If it ain't broke,,,,,,,,,,,,,,,
as they say, as blue ray is still very new, is there an upgrade???
If there is you need to get a download from Samsung, burn to a disc, and load it into your player. But if it goes wrong, as I know it can, you may as well throw the player out.
So if it's working ok, leave it so.
Jul 12, 2009 | Samsung BD-P1200 Blu-Ray Disc Player
I need to know the diminsions of the samsung dvd-v9650
Dimensions (H x W x D, inches): 2.3 x 17 x 10.8
Weight (pounds): 8.1
Dec 03, 2008 | Samsung DVD-V9650 DVD/VCR Player
Sansui dvd player wont play and dvd's... shows up as incorrect disc c104 error
Try cleaning the optics with one of those DVD cleaners.
When that probably doesn't work, you can hand clean the optics if you can figure out how to get at them. (easy on some, hard on others) If that doesn't work, it is prbably not worth going any farther
Dec 21, 2007 | Optical Coating Model 108 VHS VCR
I need the code for a Samsung DVD-V9650 dvd player
There are two possible codes for this product.
1. Hold the remote away from the DirecTV box.
2. Slide the button on the top to AV 1 or AV 2.
3. Point away from DTV box.
4. Manually turn the DTV box off.
5. Hold down the select and mute buttons at the same time until the light blinks rapidly for a second.
6. Press in one of the following codes and press the power button. 7. If the DTV box turns off, press the select button. If not, repeat steps 5-7
Possible codes: 20573 or 20820
Dec 09, 2007 | Directv RC23 Remote Control
Xbox
there is soo many ways to answer this. Have the discs ben damaged ? is the dvd player lens dirty ? the best way is to get a cd lenz cleaner cd, use it to clean the dvd player, if this dosent sort the problem look at the games u are trying to play if they are scratched bad.. then its probably the game..if not then the dvd could be faulty and the easiest solution is to buy another unit secondhand as they as cheap as chips !!
Jun 17, 2007 | Microsoft Xbox Console
Samsung DVD-V9650 DVD/VCR Player Logo
90 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
