How do i get a full screen on my macbook of the application i am viewing?
How do I get to full screen mode on my Macbook?
  • Basilio Guzman
    Basilio Guzman May 11, 2010
    You didn't mention what application are you using that requires full screen.
  • 53 Answers
There is no full screen exactly like there is in windows, however the green button in the upper left corner is what you want to click first. then if you need to get it bigger yet, you can drag from the box in the lower right corner to fill your screen. Most mac users don't do full screen like windows users do, but if you desire to have it, you just need to resize the window yourself. next time you open the program it will come up the size you left it.
Posted on Jul 28, 2009
How do i change screen resolution and text size on Macbook Air 10.9.2?
Go to: System Preferences>Displays> Click on "Display" Tab, click on "Scaled" and they change the res.
Apr 29, 2014 | Apple MacBook Air
Macbook stuck on load up screen
When you say "load up screen", I assume you mean the Apple boot screen (it has the apple on a gray background).
You might try resetting the PRAM on the macbook.
You can do this by pressing and holding the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
So, turn the macbook completely off. Turn it on and immediately press and hold the Command-Option-P-R keys until the computer reboots and chimes. Once it chimes, release the keys. Your system should boot normally.
Jan 19, 2014 | Apple MacBook Pro Laptop Computer with...
Macbook air memory full
Try quitting some unused applications > Apple Menu> Force Quit > select open applications > and quit.
Another way is to restart the Macbook. Make sure you uncheck "Reopen windows when log back in"
Feb 13, 2013 | Apple MacBook Air
I turn on my macbook air it turns on but nothing on the screen?
Hold the shift key down and start in safe mode.
Once the Macbook Air has restarted use the original install disk to repair the startup disk
Nov 28, 2010 | Apple MacBook Air
Can i expand the web page to a full screen on the mac air notebook
A very simple solution is to use Firefox for mac. Their view menu has a Full Screen command and you can toggle back to regular view via the control button at the top right corner of the screen.
May 15, 2010 | Apple MacBook Mac Notebook
I have just hooked up an external monitor (LG Flatron) to my macbook--no problem with web pages, but I am unable to see my desktop or any word files. When I boot up, it says analog in the upper right...
  1. When you connect an external monitor to your MacBook (or PowerBook, for that matter), you can combine your MacBook's LCD and your external monitor to create one big monitor. That means when your mouse pointer goes off the edge of one, it will appear on the other. Open the Displays Preference Pane to configure the resolution and orientation of the two monitors. This type of configuration works well when you want to keep your main work on your larger external display, but still keep things like IM, iTunes, and email constantly visible on the smaller laptop LCD.
  2. Some windows act like they don't want to be dragged on to your external monitor. If a windows is being stubborn, try dragging it up to the menu bar, and keep dragging, even if stays stuck below the menu bar. Sometimes once you have dragged it far enough that it has room to render the entire window, it will jump to the other monitor (Terminal used to have this problem, but Apple fixed it some time ago). If that doesn't work, try dragging it from a corner of your monitor. My Adium contact list doesn't seem to want to live on my external monitor, but I can coerce it up there by dragging up from either corner.
  3. When your laptop is open, you can't switch to using the full resolution of an external monitor. I have no idea why, but it's a fact of life for MacBook users. You can use both displays in "extended" mode, or you can mirror your MacBook's display (which most likely doesn't use the full resolution of your external monitor), but you can't switch to using only the external monitor. Very strange.
  4. If you close your laptop, you can actually get the full resolution of your external display. Put your MacBook to sleep, connect your external display and an external monitor, and wake the computer up by pressing any key. You will have full use of your external display while your laptop is closed.
  5. If you really want to have your MacBook open while only using an external display, after following the procedure above, you can open your MacBook, and it's screen will remain off, which means you can still use the MacBook's keyboard and trackpad. Why you can't get into this mode using F7, I have no idea. This is a good technique for allowing some heat to dissipate while still using an external display so the lid of your MacBook doesn't melt or warp.
  6. You can boot your computer using just an external display. Just connect your external display, open the lid, hit the power button, and close the lid again immediately.
  7. In order to output only to an external monitor, you have to have the power cable connected. I tried for several minutes yesterday to get my MacBook to wake up with an external keyboard and monitor before unpacking my AC adapter from my backpack, and it wouldn't work. It took me a while to make the connection (no pun intended), but I eventually discovered that with the power cable attached, everything works as expected.
Aug 05, 2009 | Apple Refurbished MacBook 2.4GHz Intel...
Apple MacBook Full Screen mode
Which browser are you using?
Safari, Chrome, Firefox?
Feb 28, 2009 | Apple MacBook PC Notebook
MacBook opening screen leaves a one inch black strip on both sides.
use the gray bar on top to move the screen to the upper left hand corner.  Then click and drag the bottom right portion of the screen to the size that you want it be.
Mar 21, 2008 | Apple MacBook PC Notebook
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
