Question about Philips 51PW9363 51" Rear Projection HDTV-Ready Television
No power to tv
I tried to turn on my tv this morning and it didnt do anything. i checked the outlet and changed the remote batteries and tried it manually but nothing. it is a phillips 51 in projection tv model #51pw9363/17f and is about 2 years old HELP
  • Bigscreen24 Nov 17, 2007
    Checked input fuse.. it is OK TV still will not turn on.. dead.. no action anywhere..
  • hawk97 Jul 12, 2008
    I tried to turn on my Philips 51RW9363 this morning and it didn't do anything. I checked the outlet and tried it manually but nothing. The owner's manual doesn't provide any schematics for the inner workings of the television. Where can we locate a service manual?
    Genius:
  • 1,153 Answers
You say didn't do anything, Like did you hear a squealing sound or did you see led lights on front of panel or just dead nothing? If dead and nothing then look for fuse blown in power supply if not then there maybe a small sound coming out of set when you press power if so then the power supply is trying to start up then you will have to look elsewhere like horizontal or convergence or vertical areas.
Posted on Sep 18, 2007
SOURCE:
My set is plugged into a cable box. the tv will not turn on either manually or with the remote.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken.
If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
Jul 06, 2014 | Envision L32W761 32 in. LCD TV
When pressing the remote's 'on' button tv won't come on
does it power on using the power switch on the tv itself instead of the remote? if same thing happens when pressing the power on switch on the tv directly, try to test it on another power outlet. if it is connected through a surge protector or avr, see if connecting it directly through the outlet works.
try to also check if the power on switch of the tv is somehow stuck which may cause it to try to cycle on and off and same thing on the remotes on/off button.
now if this is specific to the use of a remote, replacing the battery might help.
Mar 09, 2014 | LG 60PK550 TV
Have vizio vp50 part#1014350022 went to turn it on and nothing no lite sound or anything.Tried the reset nothing any ideas. thank you
The first thing to check is if your power outlets have surge protector breakers. Try plugging in another simple appliance like a lamp into the outlet and make sure the outlet has power.
If the outlet is fine try plugging in the TV and listening very carefully from the back of the TV for a subtle click noise. The power supply has a mechanical relay that switches when the TV receives power. If you can not hear the click and there are no stand by or power lights illuminated then you likely have a power supply problem. This could range from a blown fuse to a bad capacitor up to a burnt out power regulator. Anything more serious than those problems may warrant simply replacing the whole power supply. Depending on your TV that board could cost anywhere from $50-$175. The power supply can be tested using a multimeter to determine if it is the source of the problem but this should not be attempted unless you have some electroics repair training and are aware of the dangers involved in working on high voltage electronics.
Dec 23, 2013 | V, Inc. Vizio P50HD Plasma Television
My LG55LE5500 suddenly stopped working this morning. Last night, we switched it off in proper working condition. This morning, when we switched in ON, only the initial LG logo screen comes and stays there...
Check whether the product is turned on. I Try another channel. The problem may be with the broadcast. I Is the power cord inserted into wall power outlet? I Check your antenna direction and/or location. I Test the wall power outlet, plug another product's power cord into the outlet where the product's power cord was plugged in. From the LG manual kolbrun
Sep 18, 2013 | LG 55LE5500 55 in. HDTV LED
Vizio VL470M won't turn on
see this instruction: God bless you
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
3. test the power outlet wall see the diagram
4. do not use the r.control use the power button directly from TV.
Jul 20, 2013 | Vizio 47"" vl470m 1080p 120hz widescreen...
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Mar 09, 2011 | Emerson Televison & Video
My remote control for my rca combo 20f510td is not ejecting my dvd from the t.v. .... also actually none of the dvd buttons are doing much of anything when I press them, i.e. the play, pause, eject,...
For remote control concerns. You can try to reset your remote control but be shure before you reset your remote your tv should be unplugged from the power outlet. So here are the 4 steps to reset your remote:
1. remove the batteries,
2. press and hold the number 1 button of the remote control, thus draining all the remaining electricity.
3. put the batteries back in.
4. plug the tv on the power outlet then turn the tv on and try the remote control.
Now if these steps do not work check the warranty of the tv and have your remote be replaced if it's under warranty and if not you can try to purchase a universal remote control that supports RCA tv's.
Sep 09, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
No Power
if you need any other help please feel free to e-mail me at [email protected]
Jun 24, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
TV won't turn on
the power supply of your tv is not working,coldsolder the mainboard of your tv,
Apr 26, 2008 | RCA 32F531T 32" TV
Philips 51PW9363 51" Rear Projection HDTV-Ready Television Logo
135 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
