Question about Dell P992 19 in.CRT Conventional Monitor
Dell P992 Monitor-Need default settings for front panel buttons
I have a Dell P992 Color Monitor. My 5 year old son has chronically pushed front panel buttons for years, and onscreen color has changed over time. I then attempted to fix it myself by changing settings; of course, that only made it worse. Main window is smaller than screen now, and all colors are now dim and muddy--including white. All settings: convergence, geometry, and size/center are off now, and I would like to reset to factory defaults. I prefer brighter colors and for window to fit entire screen and would also like to lock those settings so that neither one of us can change them again. Thanx.
  • 1153 Answers
SOURCE: dell lcd monitor with vertical lines
You have a filter problem, check power supply for bad capacitors.
Posted on Sep 14, 2007
The Joat
  • 81 Answers
SOURCE: dell m782 Brightness control???
Brightness is adjusted by using the 2 buttons on the left side of the front.
See instructions here:
http://support.dell.com/support/edocs/monitors/m782/En/controls.htm
Posted on Jan 05, 2008
  • 58 Answers
SOURCE: Can't change monitor display settings
no drivers are needed for monitor. Its the video card drivers that you should look for at the dell drivers and downloads website. make sure that you have the right driver installed so that you may be increase your screen resolution.You may also use your Dell Resource CD Drivers and utilities. Install the Resource cd, On the TOPICS dropdown box, select drivers,You'll know which drivers needs to be installed because they will have a check mark infront of the correct device driver. Clicke extract button after you have chosen the video driver. You may need to scroll down.Restart the computer.
Posted on Feb 16, 2008
FixinFax
  • 3085 Answers
SOURCE: Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Posted on Jul 04, 2009
SOURCE: Flashing Main Menu on my
flashing menu control is locked again & again .how can i close it
Posted on Dec 30, 2010
Auto adjust in progress
1. Push the menu button at the front side of your Dell monitor. The icon looks look like a miniature version of your monitor.
2. Push the menu button again. This will exit the monitor menu and launch the OSD (On-Screen Display) menu.
3. Use the down arrow button on your monitor to select "Factory Reset."
4. Push the menu button.
5. Use the down arrow button to select "All Settings." Press the menu button to save changes.
6. Push the menu button twice to exit from the menu. Your Dell monitor will go back to its factory settings default, and its auto-detect feature will be disabled.
Oct 10, 2014 | Dell E171FPb 17" TFT LCD Flat Panel...
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
I recently bought a used Dell E193FP flat panel LCD monitor that was working properly on the computer it was taken from. I tried plugging it into my Dell Dimension 3000 computer and the colors are all...
1280 x 1024 at 60 Hz (optimal) resolution is the maximum resolution with 16 color if the other computer had it on 32 bit color setting or the resolution of the monitor aspects ratio changed than it will not display anything on your computer
Solution is plug in your old monitor and change the settings to lowest with the aspect ratio as what the screen size is then plug in the new one that should do it
May 16, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
My monitor's screen resolution and color depth are at a very very low resolution and I am unable to increase/improve this. Consequently, everything is fuzzy and colors are impossible to view. My monitor is...
please try doing a factory reset of the monitor.
please press the menu button on the monitor itself. you can easily locate the buttons below or on the right hand side of the screen on the monitor panel.
select the factory reset /recall options with the help of the arrow/+ - buttons.
this would reset your monitor color settings to default.
Jan 22, 2010 | CTX Computers & Internet
My monotor its all black but u can
This should be an (LCD) screen. They are the ones that usually have this kind of problem. You will need to take it to have it checked if the problem is the VGA signal cable leading to the monitor. They will check if it is properly connected or has gone bad. It is very unlikely that the screen is bad. When this VGA signal cable goes bad it could result in a totally blank screen.
Sep 13, 2009 | Dell Computers & Internet
AMW 19" LCD Monitor
go to NVDIA web site download the latest driver.
you need at least 32bit color to setup the monitor.
the 8-bit color is a default, that is why the monitor alway return to default size which is 800x600.
19" monitor should have minimum of 1280x1024 with 32 color.
don't up the color 256bit. the color will be off on the monitor.
Jan 25, 2009 | Dell Dimension 4600 PC Desktop
Dell Trinitron P992 19?nch Flat CRT monitor Driver
You can download here: http://driverscollection.com/?H=FP992&By=BenQ
Oct 31, 2008 | Dell UltraScan P992 19" CRT Monitor
Emachines monitor
Most monitors have a reset back to default display settings. Just choose this option and you should be fine. Just bring up your monitor menu and see if you have a settings menu. If you do, I bet it is there.
Nov 15, 2007 | E-Machines eMachines Monitor E15T4
Dell P992 19 in.CRT Conventional Monitor Logo
308 people viewed this question
Alun Cox
