Question about Acer Aspire One PC Notebook
Low battery warning turned into laptop not turning on at all.
Laptop although plugged into outlet will not turn on at all. It was working fine earlier. Power cord looks fine. Any ideas?
  • Anonymous Apr 19, 2009
    I have had the same problem! have you tried the power reset?
    acers website and tech support suggested that I (copy and pasted)
    Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
    If everything is plugged in correctly and it still will not power on,
    follow these steps to complete a 'power reset' of the notebook.
    1. Unplug the ac adapter. Keep ac adapter unplugged.
    2. Remove the battery and keep the battery unplugged.
    3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
    4. Release the power button and plug in the ac adapter ONLY.
      (Please note that a power indicator light should be lit on the ac
      adapter when it is plugged in).
    5. Normally power on the notebook.
    6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
    7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
      If
      the battery charging indicator light does not light up, the ac adapter
      may not be providing proper power to the unit, and may need to be
      replaced.
  • 40 Answers
I have that problem as well ill have power one minute the charge light comes on then if i move my laptop pooof its gone i think its internal maybe a loose salder leading to the power supply. so try ro check it out u might have to take it apart to check it but no u dont need a new laptop..
dragonslair2@hotmail.com
Posted on Jul 18, 2009
No power from battery to laptop
are you installing it with correct polarity
is one of the battery terminals in the laptop damaged so that it is not making contact
May 22, 2017 | Acer Computers & Internet
The power is on and the ornage light is on but thepower never increased like it should its stuck and the battery is still runny low to 27 percent and still havent gone up i have an accer computer its...
HMMMMM lukkzzzzzz lik you r battery is out, ull need to buy a new one try using da warranty card if is one year u might get a chance... acer computers have dis problem usually
May 30, 2011 | Acer Aspire One PC Notebook
Power is going to laptop but it will not turn on. Was just using it w/out power cord. Plugged power cord in and it won't turn on. Tried, Alt, ctl, delete but nothing...:(
Try switching the outlets that you're using the power your laptop. You may have a faulty outlet which could be why it isn't giving off any power to the power cord. Next, try unplugging your power cord, then taking out the battery, plugging back in the power cord and turning your laptop back on. If the laptop turns on, the problem may be with your laptop's battery. If the laptop still doesn't turn back on, put the battery back into your laptop, and see if it works. If it still doesn't work, try taking it to a place like Geek Squad in Best Buy.
Hope this helps!
-Anonymity
Feb 25, 2011 | Toshiba Satellite C655S5085 Notebook
Dell 1720; battery meter says plugged in not charging. The comptuer is running fine. 91% left in battery. Already checked device manager, drivers, wriggled the charger cable, plugged in and out several...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Your response is very much appreciated...
Feb 15, 2011 | Dell Inspiron 1720 JetBlack T5450 Laptop...
If your laptop has a bad battery, will the computer still be able to turn on when plugged into a power outlet?
If your battery is totally drained or dead, your laptop will not turn on even when plugged in to power outlet. The power from the charger don't have enough power to pass through the battery that is trying to charge. Remove the battery and you will be able to turn on your laptop when plugged in directly to wall outlet.
Sep 21, 2010 | Toshiba Satellite M35X-S163 Notebook
My Tecra Toshiba will not turn on or off, even plugged in.
Yes it is. And, it is highly recommended that you remove the battery if you're going to use your laptop for more than 1 hour. If you keep your battery in and have the laptop connected to the adapter, the poor battery is going to be charging/discharging so much that its life is greatly shortened. Also, this is what causes dead cells in batteries.
You might possibly have an internal power supply problem.
But, go ahead - remove the battery. See if it helps.
You also might try letting the battery charge for 3 hours with the laptop off.
Oct 12, 2009 | Toshiba Tecra A1 Notebook
Won't turn on
how old is the system
could be your internal plug for ac may have become lose from plugging and unplugging
or you may just need a new ac cord
try moving it around where it plugs into the laptop if you get a brief connection then it probably is the connection inside the laptop they can be replaced
Jan 16, 2009 | Computers & Internet
Won't turn on
I plugged in the laptop and let it charge for an hour, and then it worked fine. I guess the battery was too low or something.
Sep 01, 2008 | Toshiba Satellite Pro 490CDT Notebook
Have an MT6451. When I press the power button it will not turn on but the battery indicator light in front of the laptop flashes red every time I press the power button. I should also tell you that it did...
Gateway MT6451 laptop. That was easy but the rest is a guess without more details. It sounds like this computer is not plugged into an outlet or is not getting power from that outlet, and that the battery is dead low. Try plugging something else, like a lamp, into the very same outlet that the laptop is plugged into to make sure it turns on. Not the next plug over on a power strip, but the very same plug. If it doesn't get power either, there's hope. Except that your battery needs a good recharge after the laptop starts getting power.
If the outlet turned out to be good, then the power adapter on your laptop may have failed. At this point you'll need try another power adapter and try again. At this point you may need the help of people who can look at the computer for you, preferably friends with a similiar laptop (and power adapter).
I wish I could help more, but thats a start.
Mar 30, 2008 | Computers & Internet
Acer Aspire One  PC Notebook Logo
390 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
