Question about JVC AV-30W476 30" TV
Problems with JVC AV-32WR4EK
Hi, When the TV is switched on, the yellow 3D light flashes and the tv blacks out, no sound, no picture. Please advise on a solution. Many thanks.
    Genius:
  • 1,139 Answers
This could denote a power supply problem. or overcurrent protection due to a component going bad. If you do not have electronics experience, "DO NOT TRY TO WROK ON THIS SET" people have been seriously hurt trying to repair TV without knowing the basics of electronics. If this is a power supply problem it may be the HV supply and the switching power supply (IVHT based) or the low voltage starter supply. In both cases I would advise you taking it to the shop for repairs.
Posted on Sep 19, 2007
SOURCE:
Tv on,red light clicking 5 time,no picture,only sound
Hi Cornel,
No picture only sound, the back lights have failed. Please consult some good TV Tech.
Apr 25, 2015 | Samsung PN60E6500 60-inch 3D Plasma TV
Hi! I am experiencing the following three
Hi Rafael,
First of all thank you for posting your question here at Fixya.
Please confirm if the brand and model number above is correct.
Blinking of the the LED (yellow and blue) at the front panel indicating that the lamp door cover is not seated properly. This cover will engaged to a micro switch giving the signal to the processor, once it is in open position, the unit will not power up and will experienced that kind of blinking error code. Go back to the lamp door cover and ensure that it is properly seat-in.
3D, 2D, red/green/blue ghost on the picture and letters means that the convergence circuitry gone bad. Symptoms is not connected to the light engine. The faulty parts is the convergence chips(IC). This chips are mounted on the large aluminum heat sink and starts with STKXXXX-XX (X means number). The most common STK chips used on Projection TV's is the STK392-110. You have to replaced them both on the board to resolve the issue(red ghosting). It is necessary also to check the resistance value of the resistors around its circuitry using the multimeter. For more info how to repair a convergence problem, watch the video below.
Jdvillanueva
Jan 27, 2012 | Toshiba 62MX195 62" HDTV
The TV (Dynex DX-LCD32) will not come on. The
I have a DX LVD33 power light is red and no picture or sound screen is black. Please advise.
Dec 25, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Picture loss after picture begins to flash. blue and yellow light
Most likely the lamp is dying. Try replacing the lamp before calling a repair tech. What does the Owners manual say about the blink lights?
Oct 01, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 2877DB
Before you do anything else, make sure you do a hard reset. Unplug your television for an hour or two and then plug it back in. If you are still seeing the blinking lights and no picture or sound then we know of several possible prolbems that it might be. All of which require a local repair service to open the tv and replace a part.
Thanks,
Jul 03, 2008 | Televison & Video
No picture or sound
hi guys! i have a tn61x81 and the probleme with this tv is when i plug the tv the tv try to open but shut down y try to push the power botom it's make no difference the light near the power botom is flashing no power no image no sound noting. i think it's the power suply but i'm not realy shure. if aneyone can help me it will be realy apreciate.
Oct 29, 2007 | Toshiba TN61X81 61" Rear Projection...
JVC AV-30W476 30" TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
