Question about Video Game Consoles & Games
On my xbox360 the circle that has the green rings is broken.Also instead of the green rings there are 3 red rings, how do you fix that?
On My Xbox 360 the circle that has the green rings is broken. Also instead of the green rings there are 3 red rings, how do you fix that?
    Problem Solver:
  • 17 Answers
3 red ligts means you will have to phone xbox surport they will help you
Posted on Apr 22, 2009
My 360 has 3 rings the rings are red and it wont turn on
The three red lights mean that your XBOX360 is experiencing hardware failure. This is caused by overheating of your XBOX. Contact Microsoft and have them fix the problem. They have given free extended warranty for three red light problems. If you have bought your xbox360 within 3 years, you're in luck.. They will fix your console for free...
Mar 13, 2010 | Microsoft Xbox 360 White Console
It freezes when you turn it on and shuts off. and when you try to turn it back on, instead of the green ring a red ring surrounds the xbox symbol.
It sounds like the RROD. If your XBOX360 is still under warranty, you can call Microsoft and they'll fix it. If not, you can either ship your XBOX off to be fixed by Microsoft or another company or try fixing it yourself. I fixed my red ring of death with a clamp fix (http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm)
Jan 01, 2010 | Microsoft Xbox 360 Console
Need a fix for 3 red lights on xbox360
Can't fix it yourself unfortunately. It is a hardware issue. This company can fix it for you.
http://www.nexicore.com/xbox/index.html
Nov 19, 2009 | Microsoft Xbox 360 Console
My sons xbox360 has one red light and is there a way to fix or is it going to develope the red circle like his first one
this is called the ring of death and if go on to the xbox website get the num and ring them and they shoukd give you a free xbox has the ring of death if there fault
Sep 15, 2009 | Microsoft Premium System for Xbox 360
Rings of death
the "3 rings of death" or the so called "3 red lights" is actually caused by GPU overheating and mainboard flexing. When you need to do is open your xbox360 (warning, this will void your warranty) add more cooling fan inside your xbox360, you'd want to use 80mm fans coz they fit perfectly. you can fit up to two 80mm fans inside your xbox360.
Also, if you notice that your xbox360's mainboard is warped you need to fix this by disconnecting all the connections from the board. then place the board on a flat surface. then use a hair drier to heat the board and flat it out. its kinda complicated. hehe, at least you now have an idea on whats causing the 3 red lights...
May 01, 2009 | Microsoft Video Game Consoles & Games
Xbox 360 3-red lights may be caused by DVD drive? Help please!
your 360 is a first run off assembly. they were junk from the start. my warranty expired also but called microsoft and they said if the ring of death is related to the first run of 360s they willextend the warranty. exactly what happened to me. 8 days later they sent me a brand new 360 cause problems with the first run 360s can't be properly fixed. contact them tell them the problem and you will get a new one. hope this helps Tadster
Apr 15, 2009 | Microsoft Xbox 360 Console
My xbox360 has one red ring in the bottom right corner.
if it wont work at all its fried and you need to send it in, but if it does work just has that circle im not sure sorry :(
Feb 17, 2009 | Microsoft Xbox 360 Console
Flshing red light
It needs the 3 red light fix. We can fix this for you contact us at xbox360fixer@verizon.net
Jan 03, 2009 | Microsoft Xbox 360 Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
Xbox 360
okay its called the red lights of death. there are 2 ways to fix it. one go to this website. www.xbox360-fix.com orif you are under warranty send it to microsft for a free fix.
Feb 18, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
98 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
