Looking for Sony RDR HX710 firmware upgrade, hopefully to fix following problem: I know this is getting a bit old now, but I still use it a lot. After editing programs recorded on HD (such as, deleting immediately before and after the desired recording) and after replaying perfectly on the HD, the same edit points are out by a second or two when copying from HD to DVD using the onboard DVD recorder.
playback on audio cd (Compact Discs) doesn't work. When I put a DVD everything works fine but if...
(More)
playback on audio cd (Compact Discs) doesn't work. When I put a DVD everything works fine but if it's a compact disc, it plays as if in slow motion.
After formatting the RDR-HX710 says 'Disc is dirty' and don't wanna copy. Brand new discs of several...
(More)
After formatting the RDR-HX710 says 'Disc is dirty' and don't wanna copy. Brand new discs of several brands gave the same problem. Yet I don't have a solution.
I can connect my Sony KDL40V4000 tv to my Sony RDR HX710 DVD recorder using scart lead and scart...
(More)
I can connect my Sony KDL40V4000 tv to my Sony RDR HX710 DVD recorder using scart lead and scart socket to record Analogue TV. (Line 1 ON RECORDER) If I change scart sockets on the TV from scart one to scart two, the connection becomes "smartlink" but when I try ro record from Line 1 on the tv, the pictire is blank.
Any suggestions?
