Canon PIXMA MP620 All-In-One InkJet Printer Logo
Posted on Apr 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannon mp620 Printer Won't print!
I press print and all that comes up is "output file name" then i type it in and it says its printing but it isn't
Anonymous
Level 2:
Scholar:
  • Expert 62 Answers
  • Posted on Apr 19, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
62
Questions
0
Helped
27640
Points
212
Check in your Control Panel for Installed Printers. Open the window and double check that your Canon MP620 is the default printer (Check mark beside it). It sounds like you may be printer to another default location.
Hope this helps!
OpenSource13
  • Anonymous Apr 19, 2009
    Hope this helps!
    OpenSource13
    Hope this helps!
    OpenSource13
Canon MP620 not printing
Hello Maurice,
had the same problem with a previous pc i was using, best is to press (windows key + R). then type services.msc in the prompt, this will open up a new window,look for PRINT SPOOLER under the name column, right click this and set to start/auto. then exit the program and restart your pc, this will solve your isue.
Troy 8150 Printer
Yes I beleive you do need the -P
I use this on a HP 8150 I think it is Aust.version of you machine from the look of it
lpr -S 100.100.10.111 -P raw -o c:\temp\output.ps
Getting print q name
Press Menu until INFORMATION MENU appears on the printer display.
2. Press Item until PRINT CONFIGURATION appears on the panel.
3. Press Select to print out a configuration page
2nd page should be listed your print que name
or maybe just type the ip address of printer in browser and look in printers webpage.
Sorry for sketchy answer just trying to help!!
Cannon mp282 pixma ,how to fix error code 3
The E03 code indicates (1) That the Paper Output tray is closed and you are trying to print. Open the Paper Output Tray and the printer will resume printing. (2) There is a paper jam. Remove the jam, reload the paper into the printer, then press the "Black" or "Color" button,
2answers
The print que does not empty after a print job has
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Cannot print a pdf
Are you using Adobe Writer, try un installing and reinstalling
or download a app like freepdf
let me know, cause the solution depends on what software you are using.
Printer sends me to print to file instead of printing.I am using canon PIXMA MP620 all-in-one wireless printer. I have gone through the troubleshooting and still no result. Linda
First of all, make sure it is the default printer. Now, in a word or exel or similar programs, select the print option, near the properties button you will see ¨print to file¨, click the down arrow and select ¨Canon PIXMA MP620.... or similar option and print.
2helpful
Gateway Computer will not send any document to any printer
ur default printer might be set to microsoft image printer...
go to control pannel, then go in printer & fax then right click on appropriate printer & click on set it as default printer...now try printing
11helpful
Connect macbook to cannon pixma mp620 printer
You need to delete and readd the printer with a bonjour connection.
Click on the apple in the top left and go to system preferences and then print and fax.
Click on the printer name (just one click to highlight) on the left and then on the minus sign. It will ask if you are sure you want to delete - you can click yes or delete.
Click on the plus sign and you should see the printer with a bonjour (macspeak for network) printer
Click on it to highlight it and then it will look for drivers and you can then click add to add to your list.
Close print and fax window and open a document and print away!!
1helpful
Its keeps asking for my output file name when i go to print.what is a output file name ?
Sounds like whatever your printing to is set for print to file or your default printer has changed.
Go into the control panel, select printers, select the printer that you want to use and press the right mouse buttons for properties.
Select the ports tab and make sure that the file box isn't checked and that the USB port is (or whatever port your printing with).
Press ok
Make sure that you printer is set for default printer.
old marine
old marine
ZJ Limited
ZJ Limited
