Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Only have fifth gear and second in reverse on my 54 pd thrust motor guide
  • lmaster May 17, 2009
    I have the same problem (only 5th works) and I replaced the speed selector switch on the side and that solved nothing. I have the switch on the side of the foot pedal (rabbit) on order as it appeared to not be operating properly when tested with a meter
  • swizzle916 May 23, 2009
    Did the side selector switch fix it? I have a similar problem...I lost one speed at a time, until finally none of the speeds work, I might have more of a 5 speed selector switch problem. Thanks.
    Problem Solver:
  • 6 Answers
I too had the same problem. This happens because of bad solder joints where the speed coils inside the lower unit connect to the wires from the selector switch. This "cold" solder joint has a high resistance to electrical current and therefore will become hot enough to meilt the solder. If you take the lower unit apart you will find solder laying on the bottom. Just clean up the terminal and wires and re-solder and it will be fine. I also recommend you re-flow the solder on all the other terminals as well. This is a quality control problem at the manufacturer.
Posted on Dec 29, 2011
My trolling motor has same problem, I replaced the (5) speed selector swith on the foot control and that solved nothing. I have the side selector switch (3 postiion) on order after testing with a meter
Posted on May 17, 2009
Remove bent propeller shaft 25 hp mercury two cycle boat motor 2005
Take The Propeller Off,
Use The Rear Thrust Washer As a Tool Turn It Upside Down And Put It Back On The Prop Shaft The Three Slots Should Match With Bearing Carrier.,Undo Three Bolts On The Carrier In The Back Of Gear Box,
Turn Carrier Counter Clock Wise Until It Is Loose Remove Prop Shaft Complete With Carrier and Reverse Gear
Mar 16, 2013 | Boating
Gear shifter wont go into fifth or reverse
Check the shifter linkage to make sure nothing has slipped.
Apr 11, 2017 | 1999 Kia Sportage
Shifter wont go into 1st or 2nd
check shifter lever for adjustments
Jun 04, 2012 | Saturn SL2 Cars & Trucks
I have a 2006 Lowe 160 Stinger Aluminum boat. I am up grading from PD 40# to PD V2 55# which has a heavier lower unit ...Problem is this unit mounts closer to the front edge of my boat and after 6 years of...
Hey 217,
Get a sheet of 3/16" aluminum plate that is at least twice as wide as your trolling motor mount and at least 12" longer than the mount. Secure the plate to the current deck.. align the front edge flush.
You might want to radius the edges of the plate and secure it with rounded head sheet metal screws.. This will make the mount much stronger and last!!
Jul 06, 2017 | Minn Kota Powerdrive V2 Bow Mount Trolling...
Our Isuzu Fuego LS 4x2 Manual Transmission doesn't move even the shift stick is already palced in First Gear, even in second gear and third gear and fifth gear also no reverse, to sum up only 4th gear will...
you may have a shaft key broken in the transmission. 4th is usually 1-1 drive and does not need the key. before removing the transmission, check to make sure the linkage is OK by shifting gears at the transmission. If you can get other gears at the transmission, then the problem is the shifter.
Oct 16, 2010 | Isuzu Pickup Cars & Trucks
Gearbox 1985 vx jetta diesel
I would say the gearbox is toast.
Try and find a second hand one .
Jun 28, 2009 | 1985 Volkswagen Jetta
Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
May 22, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Need a drawing of the worm shaft and spool valve assy.
closest I have is 94 explorer. may be similar.
Item Part Number Description 1 3E501 Steering Gear Sector Shaft Seal 2 3524 Steering Gear Input Worm Gear and Rack 3 3647 Steering Gear Worm Ball 4 3523 Steering Gear Ball Return Guide 5 3A670 Steering Gear Worm Thrust Bearing Adjuster 6 — Locknut (Part of 3577) 7 3571 Steering Gear Worm Thrust Bearing 8 3575 Steering Gear Sector Shaft 9 3524 Steering Gear Input Worm Gear and Rack
May 09, 2009 | 1983 Ford F 250
5 speed manual transmission. reverse will not engage
I had the same problem. A spring in the gear change selector had broken making it impossible to get into reverse and very difficult into first to fifth. Simple repair. Might be similar to your problem
May 03, 2009 | 1994 Saab 900
What is wrong with my 2000 toyota celica gt 5 speed
theres a link that is shared by all those gears you have mentioned. it might be broken or maybe just got loose.
Aug 05, 2008 | 2000 Toyota Celica
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
500 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
Mike Marcotte
Mike Marcotte
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
