Question about iLO (2 GB) MP3 Player
Ilo won't turn on.....
I have replaced the batteries, the power button is not stuck and the computer doesn't recognize it. I have tried everything i can think of. Nothing works and it was working fine until battery went dead.
  • cfiscus Sep 19, 2007
    my ilo is the model Mp-556
    I don't know if the same works for this model.
    Tried it anyways and nothing?
    what next?
  • Sammii Boo Jun 11, 2008
    I turned on my mp3 player and 'No Files' appeared on the screen. So i turned it off and plugged it into the usb cable and nothing happened so after that, i kept trying to turn it on and it kept flashing 'iLO' and sometimes 'iLO' and then Searching 20%.
  • 150 Answers
Remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted. On the iLO, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the iLO will remain off during this time, making the screen appear to be blank. An hourglass should appear on you computer and Windows should say, "Found new Hardware 'SMTP3500". Launch the Rave-MP firmware update program (Start>Programs>Rave-MP> Firmware) Click "Get Firmware". Select "iLO256" and let it download new firmware. Click "OK" when prompted. Click "Update Firmware". It will now search for the iLO. This may take a while depending on how corrupted the firmware is, so be patient. After it has found the iLO, it will say, "A device has been detected in recovery mode and is being initialized. Please wait." The iLO should come back to life and start showing it's glorious "USB Connected" screen. The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start". It can take anywhere from 2 to 4 minutes to re-flash the iLO and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the iLO! Why are you still reading this? Great, did something happen? Well, If the program fails to find the iLO and gives you an error like, "Device Timeout" or something similar, you need to reinstall the iLO drivers. This can be done by inserting the iLO cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again). Plugging it into a new USB port is the fastest and easiest option though. Also check the following link for there FAQ: http://www.uiss.6x.to/ Good Luck
Posted on Sep 18, 2007
  • Patrick McGee
    Patrick McGee Sep 23, 2007
    I would tell you but apparently i am not helpful per you rating.
ILO
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Apr 08, 2008 | iLO MP3 Player
Ilo mp3 player will not power on
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Mar 02, 2008 | iLO (2 GB) MP3 Player
Keeps turning off and on
2)
Ilo 2gb mp3 player
2)
Feb 13, 2008 | iLO (2 GB) MP3 Player
Ilo mp3 player model mp-556
2)
Feb 04, 2008 | iLO (2 GB) MP3 Player
ILO wont start all the way
Reset
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Dec 25, 2007 | iLO (2 GB) MP3 Player
Doesn't power up replaced batteries
Sep 23, 2007 | iLO (2 GB) MP3 Player
My ilo mp3 won't turn on
Ilo mp3 player gets stuck on first song...
Make sure the songs are in the correct format
Aug 07, 2007 | iLO (2 GB) MP3 Player
ILo Mp3 player
Mar 15, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
262 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
