Question about Panasonic PT LC50U Multimedia Projector
Projector Panasonic PT-LC50U
My english is not good by i´ll try. The proyector does not turns on, and the display shows intermitently "e" "-" "c". The standby light it´s red blinkin, and when i push POWER blinks green once, and after stays blinkin in red. Thank you
MI PROYECTOR PANASONIC PT-LC50U ,SOLO ENCIENDE DE 2 , 10 NINUTOS LUEGO SE APAGA Y SE ENCIENDE LA LUZ O SALE LA LETRA L-n QUE DEBO DE HACER POR AQUI NO HAY CENTRO TECNICO ..
MI CORREO ES : [email protected]
gracias por darme solucion.
Posted on May 18, 2009
SOURCE:
How to do lamp reset on panasonic pt-lb50u projector.
To reset the lamp hours, turn on the projector. Then press Menu and use the Up/Down arrows to highlight Options. Press Enter then highlight Lamp Runtime. Press and hold Enter for 3+ seconds until the Lamp Runtime screen is displays. Press the Power button (any other button cancels the reset). When the Power button LED turns red, unplug the power cord to the projector. You can either use the remote or the controls on the projector. Reconnect the power cord after a few minutes.
The reset instructions are on page 62 of the user manual. The manual is available from Panasonic here: https://support.panasonic.co.nz/docstore/PT-LB50U%20Operating%20Instructions.pdf .
I hope this helps.
Jun 18, 2016 | Panasonic PT-LB50U Multimedia Projector
Mi proyector es panasonic PT-L550U, que tipo de formato es proyectado
ave a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
Nov 25, 2013 | Panasonic ET-LAE500 Projector Lamp for...
Panasonic PT-AX200U projector. input display flashes on and off.
It could be your source and not the projector. If it is a laptop then hit function four and change how it shares display. Over all I need more info as to how it is plugged in and what you are trying to view from.
Jan 08, 2013 | Panasonic PT-AX200U Projector
How to reset lamp hour of panasonic pt lam1 lamp
hi,
Do the following for reset the lamp hour timer of Panasonic PT-LM1U
1. Power ON the projector. (wait for the display)
2.Press the menu button to display main menu and then press the up arrow or down arrow to select OPTION2.
3. Press the Enter button t display the OPTION 2 menu.And press the up/down arrow to select LAMP RUNTIME.
4. Press and hold Enter button for approximately 3 minutes.
5. The LAMP RUNTIME will change to TIME RESET. (power off).
6. Turn off the power.
OK
Jul 18, 2011 | Panasonic ET-LAM1 Projector Lamp for...
The lamp lights up but not displaying anything, not even the menu. Does anybody know what's wrong with it?
Was the proyector working prior to this problem?
Check to see that the SHUTTER function is not on (press SHUTTER on the remote).
Also verify the brightness settings to check they are not on the lowest setting.
Finally check that the input selection is on the proper setting (RGB, SVIDEO, VIDEO, etc)
Clean the air filter to make sure it is getting good air.
Was the lamp recently replaced or has it been in use for a long time. These proyectors have a setting that shuts down the lamp after a couple thousand hours of use.
Hope this helps!
Mar 05, 2011 | Panasonic PT L711XU Multimedia Projector
PT-AX100U-EC DLP Projector: I replaced the bulb on the Panasonic PT-F1000NT pr...
1.Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
2. Press the ENTER button, and then press the F or G button
3. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, “LAMP RUNTIME
RESET.
” is displayed and select OK.
4. Turn off the power.
�� This will reset the cumulative usage time for the lamp
unit to zero.
***Here you go and best of luck!***
May 07, 2010 | Panasonic PT-AX100U-EC DLP Projector
Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Feb 25, 2009 | Panasonic PT-L785U Multimedia Projector
Cannot access menu screen on Panasonic PT-D3500U projector
If memory serves me correctly, there is an OSD button on the projector itself. Press that once. You may have turned off the OnScreen Display feature. If that fails to resolve the problem, please let me know and I'll look up your specific model.
Dan
May 28, 2008 | Panasonic PT-D3500U Multimedia Projector
Panasonic PT-L759U
With the power on and the lamp off, hold the input button down on the projector then press and hold the power button for 5 seconds
Nov 16, 2007 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-AE900U displays black and white only
sounds like bad cables, or wrong setting on projector you may have it set to compoent instead of composite,, you don't tell how you are hooking it up. (what type of cables you are using)
Oct 25, 2007 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT LC50U Multimedia Projector Logo
497 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
