How do you reboot on a toshiba 451c? The error message reads ''reboot machine''
  • 2 more comments
  • the_psalmist Apr 19, 2009
    I turned it off and restarted. However, the message remains the same. Reboot machine. Any other suggestions?
  • the_psalmist Apr 30, 2009
    I tried holding the c key and #8 but no error code showed up. However, when I rebooted again, this time a wrench showed up saying "call for service" and there is alphanumerical on the right corner reading "CE40" not sure what that means. But I guess I will have to call a technician now. Unless you have anymore suggestions. If not, thanks for responding.
    okay, thank you very much for all your help
  • Anonymous Mar 17, 2014
    Toshiba 451c Error code E062
  • 135 Answers
They are asking that you power off/on machine. you should be able to find a main power switch on the side of machine.
Posted on Apr 19, 2009
  • brian martin Apr 19, 2009
    if it still reads reboot machine after turning off/on at main power then you are having a Hard Drive issue, hdd will probably need replaced, is it saying to call for service, if so, you need to push and hold the "C" KEY AND #8 to get error code info.
  • brian martin Apr 30, 2009
    unfortunatly calling a technician is your only option as one of your developer units is failing to pass a close loop test and will most likely need replaced
Toshiba e studio 451c error c360
replace your toner sensor or tdk sensor
Feb 13, 2014 | Toshiba E-Studio 3511 Color Copier
Toshiba 451c "can not find HDD data" message
Had the same problem and solved inserting and extracting the card a whole bunch of times and blowing hard inside the slot. You can also try using the rubber to clean the contacts of the SD. God luck.
Nov 22, 2013 | Toshiba Office Equipment & Supplies
My copier machine Toshiba 7230 have error code CD10 when I'm copying. Sometimes The message "reboot machine" appear. How to solve the problem?
try pulling out the plug if that doesnt work try pulling the battery I believe by shutting it down you can reboot it. GoodLLuck to ya.
Dec 19, 2012 | Office Equipment & Supplies
MY TOSHIBA E STUDIO 451c HAS AN ERROR F100 CODE. WHAT DOES IT MEAN?
That code error meaning that you have a problem with HHD
1st you reboot your machine with push 0+8 than 690 start 2 set(interrupt).
If it don't wok you mast replace your HHD with a new one from Toshiba.
Aug 11, 2012 | Toshiba E-Studio 3511 Color Copier
Toshiba 451c Color Copier experiencing error F105
Hi how are you this is jack my personal Id (jack_pak@hotamil.com)
Dear follow the procedure .....
Other service call
[F105] HDD other error
(1) Check if the connectors of the HDD are disconnected.
(2) Check if the connector pins are disconnected or the wires of harnesses are open circuited.
(3) Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If
the check result is failed, replace the HDD.
(4) Replace the SYS board.
Thanks
Best Regards,
Jun 30, 2010 | Toshiba Office Equipment & Supplies
I need to set up toshiba 451C copier on network
Hi there
Foolow the link bellow for your manuals and a good online demo / tutorial
http://www.gioffice.com/Op_manuals.htm
Regards Alan "alstech"
Jun 29, 2009 | Office Equipment & Supplies
Don't know the password for Toshiba estudio 450.
default password is 12345 for toshibas...go into user functions, administration...
everything is there...
Jun 18, 2009 | Toshiba Estudio 200L Copier
Got following error: Load Error! Press any key to reboot
This problem is indeed caused by a faulty MBR but there are solutions other than zero-filling the drive.
If you can get access to a RipLinux CD there is a little utility called Testdisk that will write a new MBR code to the first block of the drive. I just did this on a Sony PCG-K15 this morning (after cloning the drive just to be safe) that was giving the same error of "LOAD ERROR- Press any key to reboot" and it worked like a charm. The machine booted right up.
Hope this helps...
May 09, 2008 | Computers & Internet
531 people viewed this question
k24674
jasbo
jasbo
