Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
A part fell off inside the dishwasher
The rear water blade fell off and I can not put it back on...how many pieces should I be dealing with? I have the blade and a small part that fits in it loosely
  • 909 Answers
Cheapest way is to go into appliance shops and look at other washers that are similar. note how theirs is assembled.
Posted on Oct 08, 2007
My dishwasher is not spraying out water. The floater fell off and I don't know how or where to put it back.
there are filters in your water lines and sometimes the drain check to see if plugged
Mar 10, 2013 | Dishwashers
Kudpo1flbl2
Check if you have at least 120 degree water temperature coming into the dishwasher. Check if the upper rack spray arm is turning during cycle. Does dishwasher sound normal, like you can hear strong water spray inside it?
Nov 13, 2011 | KitchenAid Dishwashers
When I turn on the system to start, the motor hums but nothing happens and no water comes out. We have not used it in at least a couple of months.
One Ge dishwasher when they sit for a long time and dont get used the most tends to stick. IN most cases its pretty easy to unstick it. To do that remove the lower panel below the door and you will see the pump/motor assambly, If your dishwasher is older their will be a black fan blade between the pump and motor,turn it and you fell some resistiance at first but by turning fan blade you will fell it pop free. If their is no black fan blade the fan is in the rear of the motor(aluminum colored part) turn the fin in the rear of the motor and once again it will pop free.After freeing up if you dont use regulally just start for at least 30 seconds every week and it wont stick.
Gene
Aug 17, 2011 | Maytag Dishwasher
Kenmore ultra wash dishwasher won't drain tried
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Aug 27, 2010 | Kenmore 16764 Dishwasher
I have a GE Nautilus dishwasher. I recently started hearing a clicking noise during my dishwasher cycle. It seems to becoming from behind the access panel on the left hand side of the machine. There are...
The pump/motor assembly on these dishwashers have a soft food cutter that helps to cut up smal soft food particles. This may be your problem.
These cutter blades can sometimes get loose or something can get hung up in them like a broken piece of glass or some other pieces of trash that they can not handle.
You can access these blades by removing the sump cover near the rear of the bottom of the inside of the dishwasher. remove the bottom rack and take a couple of screws out of the sump cover. you can feel down in the sump and see if there is any trash caught up here or in the blades.
If this is not the problem and you have an older dishwasher - you could have a problem with a loose fan blade in the motor. If this is the case I would run it til it dies. The motor/pump assembly is about $125+. The newer motors are a lot quieter.
If everything is working ok. I wouldn't worry too much about it.
Aug 06, 2010 | GE Nautilus 24" Built-in Dishwasher
Inside of dishwasher was dirty after cycle, baskets had black in between the screen...took out all bottom and found dirty water, a couple of inches and slime in bottom...cleaned it all out and put it back...
Check the food grinder (small blade spins against a screen) in the bottom of the dish washer drain. I found the grinder to be inoperative and clogged which reduced / stopped flow of the wash water. Also, small pieces of clear plastic food wrap can block flow.
Sep 18, 2017 | Whirlpool GU2400XTP Built-in Dishwasher
When water is pumping out it makes a horrible rattleing noise.
Hi, the problem here is you have a piece of glass or something similar caught in the chopper blade. Pull the lower spray arm out and then remove the screws and the filter and the rest of the assembly inside the dishwasher until you get to the chopper blade. Then remove the debris. Put the dishwasher back together and you should be all set. If you have any other questions please feel free to comment. Mike
Jan 05, 2010 | KitchenAid Dishwashers
It fell off
If you are unable to put it back on while the nut is still attached to the inside of the dryer, reach in and unscrew the upper arm nut. Remove it, reattach the arm to the white plastic piece and reattach the entire assembly by screwing the nut back onto the inside of the dishwasher. Very simple to do and doesn't take much strength at all. In fact, I'm usually the one that has to do it at our house, not my husband, because I can reach in and do it without removing the top rack where as he would have to remove the top rack because his arms are too big.
Oct 07, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Water does not drain from the bottom. I understand that a small amount is normal, however, this is not a small amount. Thanks for your help.
It worked for me .I have a danby countertop dishwasher.
I took off the metal top
I looked under on the left side to find the pump
I took both hoses off the pump and took off the little fan.
i took off the little metal bracket behing the little fan. and unscrewed the little pump to take it out.
the little metal piece that the fan was on wouldn't even move.So i sprayed it down with wd and it started moveing again then a screw fell out.so i found where it went(inside the motor which the fan and metal piece move) got the tweezers and replced it. oiled it some more and put it all back together. Perfect.
May 24, 2009 | Danby 22 in. DDW396 Free-standing...
My dishwasher won't drain
was it loose? I don't think it goes in there.
Nov 02, 2008 | Danby 22 in. DDW396 Free-standing...
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
163 people viewed this question
Top Bosch Dishwashers Experts
shaun taylor
Carmen Mikulic
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
