Question about Husqvarna Chain Saw 20" Bar
Starts for a few seconds, then quits
I have completely disassembled the saw, cleaned everything and reassembled and am experiencing the same issue. I am thinking nw that is could be a bad ignition coil. I gapped the coil from the magneto at .008'' (also tried .005 and .010 and got same results).
The exact symptom is that I can choke it, it starts for a second, then quits, which is normal. I then unchoke it, and is start high idle for 2-3 seconds then shuts off, which is not normal, it usually stays running after the second pull on unchoke position.
I have tested the coil and it is showing 6.77 kilo-ohms from base to cap.
Any thoughts?
  • 6 more comments
  • joh9356 Apr 19, 2009
    Sorry, I meant to mention that it the model is a 55 Rancher.
    Update:
    I have since obtained a service manual and found the gap specs for the ignition, and they are as follows for this saw:
    Air Gap: .012 inches
    Plug gap: .020 inches
    Have tried both of these but still no luck.
    All of the above recommendations have been tried and checked.
    Like I said, I completely disassembled the entire saw and cleaned it meticulously. I have replaced all maintenanceable items.
    The only thing I have not checked as of yet is the fuel line length between the tank and the carb. I know I have moved it some. It is supposed to be 115mm or 4.5 inches, and apparently is very critical. I will check this tomorrow and see.
    By the way, the saw is only 5 years old and have been used very little.
    I inspected the fuel line meticulously and found no cracks or wear or anything. I replaced the fuel filter also already. I performed the above measurements according to Husqvarna specs.
    By the way, the 55 rancher has no primer bulb. The only fuel line it has is starting at the tank: it goes fro mthe in-tank fuel filter, out through tank, through the body of the saw, into the carburetor. There is no other fuel line on this saw.
    It is still having the same problem.
    OK,
    I figured out the problem myself.
    I had to disassemble the vibration system to separate the main body from the fuel assembly. In the upper part of the fuel tank assembly there is a fuel vent pressed into the tank. This vent was clogged. I had to remove the vent, clean it out, and reinsert it.
    After I reassembled it, it cranked the first pull, and stayed running just fine.
  • Anonymous Apr 19, 2009
    same thing, a rancher 55, about 5 yrs old, starts then quits, if I get it started and give it gas, it chugs and then quits, cleaned air and fuel filters, new spark plug, no solution
  • Anonymous Apr 29, 2009
    My rancher 55 would only start after choking and then would shut off before I could get a hand on the throttle. (Starting the saw for a standing position with saw between my legs). I had been through the same check list, fuel line, fuel filter, spark plug, air filter. After reading that the solution was the fuel vent, I turned my saw on the side to see if gas would run out the vent suggesting it wasn't a clogged fuel vent. Gas did run out, so I concluded it was not the fuel vent. Just to be safe, I removed the fuel vent anyway, cleaned and reinstalled. The saw started up like new and ran like always! I can't explain why gas would run out, but air wouldn't go in??? Thanks for the help everyone!
2 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: Starts for a few seconds, then quits
You will have to remove the air breather and carburetor to make the job easier. You will then be able to access the fuel lines easier. You may also need to take the gas tank off. While you have the carburetor off, it might be a good idea to clean it as well. Use a Den Tek Brush, (used for cleaning teeth), for small ports in carb. And depending on how old your chainsaw is and how much it is used, you may want to go ahead and get a carburetor kit and replace the needle valve, small screen, and appropriate gaskets. Sounds like it might just be your fuel lines though.
Jim
Posted on May 29, 2009
How do I fix that irritating squeaking noise?
More than likely an idler pulley assembly issue. Best bet is to order a replacement. You might as well replace the drum belt too since it means a complete disassembly of the unit for proper access, cleaning and repair. If you don't have the know-how it's best left to an experienced technician.
Jun 29, 2014 | Frigidaire Dryers
Display goes off after few seconds
Possibly you have an overheating GPU or CPU problem. If you can do it, then disassemble the laptop and:
- Clean up everything (use canned air),
- Replace the cooling pad or cooling paste of GPU (if applicable) and CPU,
Reassemble the laptop.
Before you disassemble this laptop, you can check the air inlet, air outlet and the fan, and clean them up using canned air. I hope it solve the problem.
Mar 06, 2014 | Lenovo ThinkPad SL400 Notebook
It starts the cycle then buzzes that its done after a minute and sometimes after the cycle is complete, the clothes are still soaking wet.
Hello Michele Taylor - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly, faulty pump or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. I strongly suggest consult a professional for a proper diagnosis and to assist with the repairs.
Feb 10, 2013 | Frigidaire ATF6000ES Front Load Washer
Chainsaw stalls
Not sure what to say other than its fuel starvation, if not already done replace the fuel filter in the tank, if no better i would suspect a massive air leak, so replace the crank seals, if there is no primary compression in the crankcsae fuel will not pull through the engine, good luck.
Feb 05, 2013 | Echo CS400 18" Chain Saw
When I start a cycle it starts to fill for a second and then stops.
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Oct 23, 2012 | Frigidaire GLTF2940ES Front Load Washer
I have a $120 10"
It's possible that the brushes may have worn out or a bad connection may have developed in them or at the brush holders. Open the motor, check the brushes and look for any overheating. One of the windings may have gone open circuit in the armature of the motor and in this case it probably isn't worth repairing.
Mar 11, 2011 | Ace Hardware Ace; Table Saw with Stand
My poulan Wood Shark mod.1950- Dosen't seem to be oiling.I've cleaned everything you can clean and I can't find the oiler adjustment.Is there one?
A link to a Poulan "1950 Gas Saw Type 7" can be found below, (I did not see an oiler adjustment screw) follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/1950-Gas-Saw-Type-7/75.1950-Gas-Saw-Type-7.1.59.1.html
The IPL (exploded parts list) for your saw is the only detail for the Oil system and is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
Poulan.com (all models)
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 02, 2010 | Garden
Cannot reassemble brake band assembly to clutch drum
The brake was engaged when removed. The Illustrated Parts List (IPL) here shows how the majority of components fit together. The brake needs to be released to clear the clutch drum.
Secure the clutch cover (it requires quite a bit of force), with a couple of blocks of wood, in a large vise or a C-clamp on a work surface.
Use a pair of pliers or a crescent and rotate the spoked part CW until it latches. This one is latched.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 16, 2010 | Husqvarna Chain Saw 20" Bar
Jim
May 23, 2009 | Husqvarna Garden
Echo CS440 wont idle when warmed up
Check for air leaking at cylinder to block.gasket.
Mar 18, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Husqvarna Chain Saw 20" Bar Logo
461 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
