Question about Cyberhome CH-DVD 300 DVD Player
Where can I find screw
I NEED 5 SCREW M4L10 I HAVE ASSY STAND P-BASE AND I CAN NOT PUT THIS BASE TO THE PLASMA TV FROM SAMSUNG
  • stoneheaded May 11, 2010
    This question is in the wrong place try using the samsung tv section.
How do you assemble the stand to the tv
This is a pretty easy job.U have the four Philip screws that came with the tv base stand wright?U have a Phillip screw driver wright?Just put the base stand into the tv make sure all the screws holes lines up between the tv and the base stand holes.Than just tighten the Phillip screws with the Philip screws driver,than u are done.
Jul 14, 2011 | Samsung LA40A450 40 in. LCD TV
Where can i get replacement screws for the base/stand for my lg 50PX1D 50in plasma tv?
I belive the screws you are speaking of are 5 mill 20 thred per , I have found them at local TV shop. They will give them to you if you ask. IF you can not find them local, e-mail me.
please leave feedback
Feb 20, 2011 | LG 50PX1D 50 in. Plasma Television
How do I install the base stand?
Just put base stand into a hole of the main LCD tv unit at bottom base hole and make sure all the screws holes lines up.Put in those holes with 4 or more philips screws on those holes and now just used a philip screw driver turn it clockwises to tighten those philip screws for it to hold on to the base stand.
Feb 05, 2011 | Samsung LN46A530 46 in. LCD HDTV
Samsung 4235X/XAA older Plasma TV Need to take the base out for m
GENTILITY lay that set face down on a table covered with a thick blanket. There should be 4 long threaded bolts near the bottom that fasten the legs of the stand inside the framework of the set.. Remove these and the stand should slide right out.
www.mcveyelectronics.com
Apr 11, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Removing swival base
Most LCD TV's have 4 or 5 screws attaching the stand to the set near where the stand slots in at the bottom. The screws might be covered by a plastic panel.
Hope this helps.
Andy
Jun 25, 2008 | Televison & Video
Remove base from television
Remove 2 screws on the back bottom by the stand.
Remove 4 screws, two on each side about 3/4 of the way toward each edge.
Pull TV up to remove from stand. Put plate and 2 screws back.
Can see this if you download the manual from the hitachi site. Just do a search for the model no. on their site's search engine.
Mar 22, 2008 | Hitachi P42H401 42 in. Plasma HDTV
Cyberhome CH-DVD 300 DVD Player Logo
78 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
