Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
MY WEBCAM WON'T WORK ON WINDOWS LIVE MESSENGER. wHAT AM i DOING WRONG?
  • lilchris173 May 11, 2010
    First you have your caps lock on and you didn't look before you clicked submit ;-). Other than that, you aren't being clear enough for me to help atleast. I suggest having a techy person use www.teamviewer.com and login to your PC remotely and fix it. I don't have time to do it, only come on here for a sec, but if you had spent the time first to make your message a bit more detailed you would have had an answer sooner :-)
  • 3 Answers
Right click on my computer... go to device manager and look for the webcam. Make sure it doesn't have a yellow flag. If not, then go to task manager and make sure another program that uses the webcam is not using it. It can not be used in more than one program at a time
Posted on Apr 19, 2009
3 Suggested Answers
  • 4 Answers
SOURCE: Logitech webcam won't work on windows live messenger
This could a problem of compatibility. Try to find if your web cam is compatible with windows live messenger for this you have to download from microsoft "amcap.exe". Run it and if you have more than one webcam installed, click the Devices menu and select the one you want to use.
2. Click the Options menu, then click “Video capture Pin.”
3. Under “Color Space/Compression:”, choose one of the following formats:
o RGB 24 (recommend)
o I420
o IYUV
Note: If one of the options above isn’t in the list, then your webcam is not compatible.
Under “Output Size”, choose one of the following:
o 160 x 120
o 320 x 240
5. Click OK
6. Close the ampcap application.
7. From your desktop, click ‘Start’ and select ‘Run’.
8. In the run box, type: dxdiag
9. In the confirmation dialog box, click OK.
10. On the System Tab under ‘System Information’, look for DirectX version. Verify that your version is DirectX 9.0. If it is, just click Exit. If your version is older than 9.0 (any lower number), download the latest version of DirectX from Microsoft.
Posted on Dec 09, 2008
SOURCE: Acer Aspire 5535 Webcam wont work on windows live messenger
I had the same issue when i installed new Messanger 2009. I found another thread that states that it is Macfee site advisore is the problem go toprogramm files / macfee / site advisor. in that folder look for the file sasets.ini....
right click on the file and open with notepad scroll down to see the following and change the (1) to 0
[msnmsgr.exe]
Enabled=0 ........... change the 1 in this line to a 0
Type1=0
Type2=0
NotifyChange1=0
NotifyChange2=275
EnumID=7
then save restart it shoild work
Posted on Mar 01, 2009
Camera won,t work on windows livemessenger camera works fine but not on live messenger. Download was fine,everthing went well
Use the latest version of Windows Live Messenger. Download here.
Install and open Messenger.
Go to Tools -> Audio and Video setup...
Click next and make sure your camera is selected!
Accept and starting video-chatting! :)
Mar 13, 2010 | Microsoft LifeCam VX-1000 Webcam
There is no webcam available in Windows Live messenger. In Skype and Windows Messenger the webcam is well availble. What is wrong? It is a new N310 with windows XP. A second installation of windows live...
Tools > Audio and video setup...
Follow the instructions on the setup screen and once its finished, you will find that the webcam should be able to show up.
If it doesn't show the webcam on the other person, tell him to switch his status to busy for 5 seconds and then back, hopefully that should come up on the other persons screen.
If this hasn't work in most cases it should work - You will have to downgrade to Windows Live Messenger 8.5 and hopefully it should work.
If this hasn't work, go to the HP website and search up webcam drivers for your device and then install it on your computer - Hopefully your webcam would work.Download reginout intel partne to fix messenger registry problems
Jan 15, 2010 | Samsung N310-13GB Netbook
My Logitech webcam won't connect via skype.
can do one thing,, just uninstall the windows live messenger ,, once, and check with the skype,, then try installing windows live messenger....see whether it works..
Sep 28, 2009 | Logitech Quickcam Chat Webcam
My webcam wont work with windows live messenger beta
Restore your system to the date when your web cam is working.
Apr 15, 2009 | Microsoft Windows XP Professional With...
Webcam not working
Windows Messenger is pretty much hit and miss. I have a built in webcam on my laptop. Sometimes it works sometimes it doesn't. There's no real fix to this problem, just cross your fingers. Restarting your computer works sometimes but not always.
Mar 18, 2009 | Microsoft Live Vision Camera for Xbox 360
Webcam does not work on Windows Live Messenger
UNINSTALLMSN RESTART AND REINSTALL
THEN FOLLOW STEPS
After you start Windows Live Messenger,
expand the view by clicking on the square
on top left next to the red X.
Then on the Windows Live messenger window on the
right side, click on “ “Show Menus.” And then click
on “Show the Menu Bar”.
Next go to the Menu Bar on right side, click on Action.
Go to “TOOLS” and click “Audio and Video Setting
and follow the instructions.
IF YOU STILL HAVE PROB LET ME KNOW AND PLEASE DON'T FORGET TO RATE THANX
Feb 01, 2009 | Logitech Webcam
I have my yahoo messenger finally working after losing it. I can now see my text, but before that my webcam was working. So I thought Great! I got both up and running, but I was wrong. My webcam says the...
hi,
please try into install windows live messenger.
Microsoft lifecam vx-1000 work well with windows live messenger . you can download the live messenger from microsoft website
Dec 15, 2008 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
When i am on msn and want to put on webcam a message appears in a conversation saying Messenger is not available right now. Please try again later. (0x8ac70202)
This might be a compatibility problem between your webcam drivers with the new Windows Live Messenger program. You may want to:
1. Update your webcam drivers and see if Windows Live Messenger can detect it when you run the Audio Video setup from its Tools menu.
2. Or you can downgrade back to the older version of Windows Live Messenger which is compatible for your camera. Doing this however also requires that you uninstall all the Windows Live Beta products from your computer.
Note: You will not see a separate Windows Live Messenger on your Add/Remove programs, instead you will either see there Windows Live Beta products or Windows Live Essentials.
You can download the older versions of Windows Live Messenger from:
Windows Live Messenger 8.1:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
Windows Live Messenger 8.5:
http://www.microsoft.com/downloads/details.aspx?FamilyID=7a1aae73-48cc-4f7a-b445-0487bd5e84ef&displaylang=en
~ Carlos
Nov 10, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
1,271 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
