Question about Fujitsu Siemens MCM 21P3 (White) 21" CRT Monitor
Suddenly blank While I'm using it , suddenly it went black & the green power light still as it is. I restarted my computer , changed the power & Data cable , unplugged the data cable only But all made no effect. I tried another monitor and it works fine. I've doubts that some thing changed the monitor setting to "Input B" instead of "Input A" which the data cable is plugged to. any Idea about how to switch back to "Input A" or what is the problem ? For knowledge, I don't have any devices like "Video , TVbox ,...etc" which I can plug to "Input B".
  • mmaafs Sep 21, 2007
    No , It happened suddenly
    Thanks , I'm going to buy a new one
    I want it to be also 21 CRT Monitor
    which company & model would you advise me to buy ?
    Scholar:
  • 68 Answers
Did you know any subtle changes in monitor performance before you had this problem. Maybe a flicker or lines running down the screen?
Posted on Sep 20, 2007
  • Anonymous Sep 21, 2007
    It sounds like your monitor has failed. If another monitor works fine but this particular one is not showing any picture. I would bet that your monitor is no good. The best solution to this problem is go and buy another monitor. To have it repaired would cost almost as a brand new monitor.
    I build custom computers and I have had good luck with this one.
    Samsung SyncMaster 216BW 21.6" Widescreen LCD Monitor - 5ms, 1000:1(DC 3000:1), WSXGA+ 1680x1050, Gloss Black, DVI-D, D-sub, 300 cd/m2
    also sounds funny but I also use I-INC monitors. Cheaper price but in contrast good performance low temperatures.
SOURCE:
Have an xps 200, monitor suddenly went black the other day in the middle of use. Noticed the power light had gone from green to amber. When I push button on monitor says it is in power save mode, to move...
Try connecting the monitor to a friend's computer. If you get some sort of a display it's not the problem. When you say that the computer makes a new noise like the fans are spinning fast, you might have an issue with the video card , motherboard, or power supply.
Aug 05, 2013 | Dell XPS 200 PC Desktop
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
The monitor suddenly went blank and displayed "no
no signal coming out from the video card input to your monitor. better check if the vga cable is properly fix on the video card and the monitor. you may need also to disconnect the video card from the motherboard and reseat it properly.
just make sure computer is turn off when you do this.
let me know if i can help you further.
Feb 01, 2011 | HP Pavilion a1210n (ED895AA) PC Desktop
Try to pull out video card and clean the slot on motherboard then put video in. If no result replace video card.
Feb 01, 2011 | HP Pavilion 6730 PC Desktop
Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
Jan 04, 2010 | Computers & Internet
Monitor screen went blank after changing resolution
Try unplugging the monitor and then restart, and then go back to default settings.
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
Blank monitor
Try unplugging the power cord to your computer tower, click the power button to drain the capacitors in the mother board then plug the power cord back in and try to boot up. Has helped me repair several similar black screen problems. Chuck [email protected]
Jul 24, 2008 | Star Logic 17" LCD Monitor
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Screen black
toshiba cosmio f10 laptop screen is not working. Totally black. from start nothing there. just black.
Dec 09, 2007 | Acer Aspire 5100 Notebook
Fujitsu Siemens MCM 21P3 (White) 21" CRT Monitor Logo
250 people viewed this question
Top Fujitsu Computers & Internet Experts
Ekse
Alun Cox
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
