Question about SanDisk Sansa e260 MP3 Player
Hi I bought scandisk e260 without cd, when I connect it to the computer, the computer ask me to locate driver. Where can I get driver? thanks
    President:
  • SanDisk Expert
  • 652 Answers
Try connecting it to another computer and see if it will recognize it as sansa or removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansa and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier Make sure USB mode is MSC I use my computer to drag and drop my music from my music folder to the sansa media folder.... Open my computer click on folder what ever folder has your music in it and drag to media folder and drop (click on the (+)where it say's sansa ) easier not to sync
Posted on Apr 19, 2009
SOURCE:
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Feb 17, 2011 | SanDisk Sansa e260 MP3 Player
Sansa scan disk mp3 player
put the songs in the removable drive.... it will work...'
for all mp3 player.. there will be any data storage device...its real..
thank u
Aug 11, 2008 | Electronics - Others
Unable to connect my sansa e260 player in pc
To obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
Jul 27, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Problem
has the software
Jun 30, 2008 | SanDisk Sansa e260 MP3 Player
NEED A DRIVER FOR LG 6250 HANDSET
I HAVE LG 6250 BUT WHEN I BOUGHT IT I DIDN'T GET ANY CD........ WHEN I TRY TO CONNECT MY COMPUTER IT ASKING FOR DRIVER SO HELP TO FIND DRIVER FOR MY HANDSET....................
Apr 14, 2008 | Cell Phones
I need to install drivers for my sansa sandisk
Well I found out that if load the the firmware upgrader on your computer and then
slide the power switch to hold position and then
keeping the select button pressed down
plug it to the computer.
Hold it for say 15 sec and then let go.
In a minute or so the firmware updater will pop up asking you to check for firmware upgrade.
choose the default and follow the prompts
your frown will turn to smile.
Apr 09, 2008 | SanDisk Sansa Clip MP3 Player
Problems without drivers of sansa e260 mp3 player
Follow the link below to obtain the driver for your device..Select your device model and operating system4.gif.....
I hope4.gif this helps4.gif..
Thank you
Computerrep
Mar 14, 2008 | SanDisk Sansa e260 MP3 Player
How to insall sansa e260 mp3
My same player did not come with the CD. Depending on which program you use to get your music on your player, the CD is not needed. Try connecting your sansa to your computer and open whatever program you use for your music.
Jan 01, 2008 | SanDisk Sansa e260 MP3 Player
Frozen in song.
The sansa e260 seems to have a hell of alot of faults. If SanDisk brings out a firmware upgrade definately take it, also I would strongly suggest that you write a letter to ScanDisk letting them know the grief it has caused you. I have an e260 and it has not had any problems so far, so I guess theres a little give or take sorta thing happening here.
Dec 30, 2007 | SanDisk Sansa e260 MP3 Player
Cruzer Scandisk 2.0 titanium
Hi, Not unless you are using Windows98, your PC should automatically recognize the SanDisk Cruzer Titanium as a "Removable Storage/Device". Driver is not required for Windows ME, W2k or XP. If for some reason the SanDisk Cruzer Titanium (non-U3 devices) is not recognizable, then perhaps it is not a problem with the PC but with the SanDisk. Pls try all other USB ports of your PC (front and back). The SanDisk website provides utilities/software for this kind of eventuality. They are Sansa Firmware Updater and Sansa Connect Recovery Tool. Both are available at http://www.sandisk.com/Retail/DriverDownloads.aspx. Pls be forwarned that some utilities can and will reset your SanDisk to default and any or all data can and may be deleted. Hope this be of some help/idea. Pls post back how things are or should you need additional information. Good luck and kind regards.
Sep 30, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
SanDisk Sansa e260 MP3 Player Logo
118 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
