Question about Husqvarna Forest & Garden #952802239 235E 16" Gas Chain Saw
Can't start a new Husq 235 chainsaw. I put new gas/oil in about a month ago and it ran great. Tried to start it today and it acts like the ignition is not ''on''. I primed it, choked it, tried holding the gas wide open, and nothing...It smells like it's flooded, but even after waiting, no workie...
    President:
  • 2,220 Answers
My 359 floods easily. Follow the procedure in the manual but listen and once she tries to start open the choke. About 2 pulls on mine she pops open the choke 1 more pull and she's running. When warm pull out the choke (sets fast idle) then open again without trying to start her. I made the mistake once of trying to start her without fast idle... took 2 weeks for my shoulder to recover...
Lou
Posted on Sep 09, 2009
  • 60 Answers
Take it back to dealer.
Posted on Apr 19, 2009
Honda 6500is wont start ran about 6 months ago drained fuel put new fuel in still wont start.
make sure you are getting fuel to carb, also check spark plug
Jun 12, 2011 | Garden
I was given a mini mac 30 chainsaw. it ran great ...
Most chainsaws in the United States operate on a 50:1 oil to unleaded gasoline ratio. Some manufacturers recommend a 40:1 mixture.
May 18, 2010 | Garden
I have a older remington gas powered chainsaw (model SL16)- I rebuilt the carb (new diaphragm and gaskets), started it , did some adjustments and it ran great- When adding bar oil to the bar oil tank and...
An impulse line from the crankcase pressurizes the oil tank to force oil to the chain. On the bottom of this line in the oil tank is duck (one way) valve. I think it has failed (open) and you are sucking bar oil into the crankcase. Loosen the oil cap before putting her to bed to help stop the bar oil from weeping. Key word Help. LOL HTH
Lou
If this doesn't solve your problem try here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
Do a search for your saw it has probably been asked and answered. They will help if my suggestion doesn't work and you can't find an answer.
Oct 20, 2009 | Remington Garden
Does 2 cycle oil get mixed with gas on McCulloch chainsaw or just put gas in?
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Oct 14, 2009 | McCulloch Garden
I have a older poulan chainsaw it ran good acouple months ago. i tried to start it today it would not hit.changed plug still nothing
Remove all fuel and discard. Use fresh fuel. Clean the air filter or replace.
Make sure you keep the chain tensioned properly and wear good chaps.
Aug 29, 2009 | Garden
Husqvarna 223l trimmer shuts off
See if air cleaner is plugged or needs changed or cleaned
May 21, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Wont start
Start with emptying the gas tank totally. Refill with fresh gas/oil mix. Todays gasoline ain't that great.
Also after putting in fresh gas and priming if it doesn't fire at all pull the spark plug and if it is dry, pour a about a tbsp. of mix gas in the plug hole. put the spark plug back in and see if it will fire.
Phil
Dec 07, 2008 | Garden
1997 GMC K1500 4x4 5.7 ex.cab SFI injection system
I would check the fuel lines themselves and make sure there is no blockage. If not you might want to check your fuel injectors and see if they need to be replaced. also make sure you didnt install fuel filter backwards.
Nov 20, 2008 | 1995 GMC Jimmy
fuel pump died replaced it truck ran poorly afterwards. Had a prussuer test done pump determend pump was no good. Put in another ran good for 2 days started running poorly hard to start no power. 2nd fuel pump. So i figure another bad new fuel pump wow changed it put in a third brand new fuel pump. Still will not eve start now. I had it tuned up 2 months ago new plugs rotor, cap, etc. put in a new fuel filter made sure it is on proper checked all connections for leaks. this cannot be a fuel pump problem now. no problem with the elctrical i figure i have great spark on ignition tester. I can hear the fuel pump prime when i turn the key. but when i went and checked the fuel port i had no pressure. When it is being cranked gas sews out of the test port. Also i dont if this is comon cause i used to turn my keyand go. but when i have someone turn the key and i listen at the gas tank whn the key is shut off i hear gs spraying back into the gas tank. So i am open for opinions.
May 18, 2008 | 1993 GMC Sierra K1500
Husqvarna Forest & Garden #952802239 235E 16" Gas Chain Saw Logo
820 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
