Question about Baby Lock Eclipse Serger
The order in which to thread the serger
What is the order in which you thread the serger?
  • Baby Lock Master
  • 12,537 Answers
Sergers are complicated and finicky. Some sergers require the threads to be threaded in the proper order, and if not done so, the serger will never work. Consult your owner's manual. My machine requires the upper looper be threaded FIRST, then the lower looper second (with the thread tail draping over the upper looper), then the needles are threaded last. If it's not done in that order, it will give me fits until I do it right.
Posted on Jun 01, 2015
  • 128 Answers
Your serger should be color coded for threading. Just do one at a time either left to right or right to left with the cones. And you should be all set.
Posted on Apr 20, 2009
I have a singer profession 5 serger. The chainstitch keeps breaking.
Thread breakage occurs most often because the machine is not threaded correctly or is not threaded in the correct order. Remove all the threads from the machine. ALWAYS RAISE the presser foot and rethread. Be sure to thread each in the correct order and that each follows the correct threadpath.
Nov 05, 2017 | Singer Sewing Machines
Viking Huskylock 560 ED threading diagram
Viking 560 ED Huskylock Handbook
Threading Serger this may be helpful even if it is not the same model. The sequence of threading loopers is VERY important. If you thread them out of order, be prepared to be frustrated beyond belief!!! Something else (I don't think she mentioned) is to ALWAYS RAISE the presser foot when threading your machine. This is true for sergers AND sewing machines!
How to thread Serger
Nov 17, 2016 | Sewing Machines
Why does lower looper keep breaking
probably need a adjustment, you may have to have the looper checked
May 26, 2016 | Sewing Machines
Is there an order to threading the machine? My green looper thread comes out of the needle and it will not serge
The answer is: YES! Most sergers have a specific order to the threads, and if not followed, there's a possibility the machine will never work properly. You should consult an owner's manual for your machine, but most machines should be threaded:
Most Important: Always RAISE the presser foot when threading the machine. This releases the tension disks and allows the threads to seat properly. Also, when threading, give each thread a little tug going through the disk to confirm it is seated all the way--sometimes it will actually make a little "pop" when it seats.
Something you can try is install brand new needles if they are causing a problem. Needles should be changed frequently as they wear and are damaged through regular use.
Here's the threading order for a lot of machines. First thread the upper looper thread, then the lower looper thread with the thread tail "draped" over the top of the upper looper in its final threading process before threads being pulled under the presser foot and toward the back of the machine. Needle threading is usually not as important in the threading order process, but they should not be twisted and their thread paths should be correct.
Of course, be sure to pull at least 6 inches of thread tail so the threads are not pulled out when stitching is begun.
The Anatomy of The Best Serger Tension My Tips Bonus Unpick it Serger...
Make It Handmade Threading Your Serger or Overlocker
Lower looper woes on my serger
May 23, 2016 | Sewing Machines
My serger is still not working properly trhread still breaking lower and upper
Generally, thread breakage is due to incorrect threading, threaded out of order, tension too tight, or the threads are looping or hanging up on their way through the thread path. Be sure to remove ALL the threads from the machine and RAISE the presser foot while threading. Give each thread an extra little tug when going through the thread tensioners to make sure they are seated all the way. Consult the owner's manual to verify the thread paths are correct and the threads are threaded in the specified order. (If not threaded in the proper order, the serger will most likely never work satisfactorily.) Perhaps changing thread brands will help--and avoid old or bargain bin threads. Set the tension guides to the midway point between high & low numbers before testing.
If there continue to be issues, the timing may be off or a looper may be bent. Take it for service.
Make It Handmade How to Thread Your Serger Out of Order
sewing patternreview com
https://answers.yahoo.com/question/index?qid=20120705022414AAvIeRH&submit=y
Serger threads Threads Magazine Gatherings Forum Sewing Questions Answers
serger thread keeps breaking help
Mar 19, 2016 | Sewing Machines
Pushing material away, but still overlocking
It is difficult to tell what exactly is happening with your serger.
First thing--make sure you RAISE the presser foot BEFORE you thread any of the threads. This releases the tension disks so the threads will seat properly. You may need to remove all the threads and rethread from the beginning, making sure you thread each in the proper order. Start out with the thread tensions set at the ideal setting--usually the halfway point between the high & low numbers. From there, you will adjust them to even up the thread tensions.
Are you actually trimming off some of the fabric as it is stitching? If so, you might try increasing the cutting width (moves the cutting edge further toward the right) so that there is more fabric caught within the looper threads. It also appears that the looper tensions may be too loose. Try tightening the upper and lower looper tensions so less of the thread loops don't fall off the fabric's raw edge.
Make It Handmade Understanding Your Serger Features
Serger Stitches 101 Cheat Sheet Never Ever Without It Your New Must Have...
Meet Serge Beginners Guide To Using an Overlocker Serger
Using Serger Learn to Use Your Serger to the Max
Bernina 700D Serger 8 Cutting Width Knife Adjustments
Dec 30, 2015 | Sewing Machines
Why does the upper looper thread keep busting?
Quite possibly the machine is not threaded correctly, the tension setting for that looper is too tight (could be the upper looper tension disk is stuck or dirty causing the thread to hang), or the thread is looped around something like the thread tree.
Replace the needles. Remove all the thread and re-thread from the beginning. Be sure to RAISE the presser foot before threading. Make sure to thread the threads in the correct order.
Serger Troubleshooting For Any Serger Serger Machine Series Ep 4
Nov 01, 2015 | Brother 1034D Serger Sewing Machine
The serger will not form the initial chain. Have checked threading and have new needles, any ideas?
It's an odd thing but on my serger, it actually matters the order in which I thread it. I *try* to tie the new thread to the old and pull it through rather than re-threading, but when I've had to re-thread, I've had trouble getting it to loop again when I thread left to right. It seems that the loopers only loop if the right looper is threaded before the left.
Apr 16, 2015 | Sewing Machines
When we thread the serger . the thread is still skipping
Are you using the corfect serger system needles in it? Most domestic sergers will take the regular domestic needle 130/705X but work best with a serger needle with has a groove down the front as well as the regular back scarf. This helps with the thread pickup from the looper by the needles. Sergers also run much faster than domestic sewing machines so the tolerances are very fine.
My Bernina came with ELX705 needles and it does run better with these in it. Also you need to use mid size needles, don't go too small, probably a size 80 or 90 is best.
Check out this page for some good info as the different serger manufacturers do have their own recommended needle sometimes. http://sewingmachine221sale.bizland.com/store/page78.html
Always refer to your manual (or ring the manufacturer if lost) to double check what needle they recommend be used in your serger, it does make a difference.
May 19, 2011 | Sewing Machines
I bendt my needles, and after changing them it wont sew. the threads just come out without getting sewn together.. just 4 straight threads..
Once the thread breaks, the serger usually has to be re-threaded - all four components of the serger.
Raise the antenna to it's highest position.
Open the tensions to zero.
Turn the handwheel so the the loopers are at their highest position. Some sergers have a mark on the handwheel that aligns with a mark on the side of the serger for this step.
Thread according the the sequence indicated on the threading guide - this is either on the inside of the door or on the serger.
Mar 14, 2010 | Janome MyLock 644D
Sewing Machines Logo
478 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
