Question about Watches
I have a jaga digital watch. It has a light/adjust/set and mode button. How do I set it for the time and then use the timer. it has a 8 lap memory. Hannah
Hey. so you hold the set button down when your on the time mode, then the hour digit flashes and press the adjust button till its the right time, then the mode again to flash the minutes, then adjust till its the right number then that should be like it. once youve got the time and date and everything right press set and it should be done. hope this isnt like rela late or anything. x
Posted on Aug 26, 2010
  • bbkhigu
    bbkhigu Nov 03, 2013
    idiot ni helpful post
I cant set the time on my adidas duramo watch. It says 'offset' and below it says '1H'
This has already been posted on Fixya, so I take no credit for it. I've put the original reply below :-
Directions for setting the time on the adidas duramo / furano / uraha / paruko watch 1. press and hold the SET/LIGHT button (upper left) until "light on" or "light off" is displayed 2. press the MODE button (lower left) until "hour" is displayed and the hour digits are flashing 3. use the START/STOP (upper right) button to increase the hour, and use the LAP/RESET (lower right) button to decrease the hour 4. press the MODE (lower left) button again and "minute" is displayed and the minute digits are flashing 5. use the START/STOP (upper right) button to increase the minute, and use the LAP/RESET (lower right) button to decrease the minute 6. press the MODE (lower left) button again and "second" is displayed and the second digits are flashing 7. use the START/STOP (upper right) button or the LAP/RESET (lower right) button to set the seconds to "00" 8. press the SET/LIGHT (upper left) button to accept the changes
Aug 31, 2017 | Adidas Watches
Tip
How to set your Global Atomic G-Force digital watch
This watch says "Strong Ideas" on the back instead of a 4 digit number.
Press LIGHT briefly and your LCD will be back lit for 5 seconds.
Press MODE to cycle through normal, alarm, dual time, and stopwatch display mode.
Hold MODE for 3 seconds to enable the radio to receive time signals. Once RC is activated, the watch will search for time signal automatically every day.
Hold LIGHT for 8 seconds to disable the RC function.
Press MODE, SET, and ADJUST simultaneously to reset the watch.
Press ADJUST while in normal mode to toggle year/time display.
Press SET while in year display to alternate Month-Day or Day-Month.
Hold SET for 2 seconds while in normal mode to cycle through world atomic radios (US/GB/DE/JP) push ADJUST to change, and SET to continue. Next the language will flash (GB/FR/DE/ES/IT). Next is DST on/off. Next, in order are hour, minute, second, year, month, day, and 12/24 Hr format.
(US only) Press SET to display timezone. The default is PA, use the ADJUST button to cycle through MO, CE, or EA as desired.
Press SET while in alarm mode to toggle alarm on/off.
Hold SET for 2 seconds while in alarm mode to change the hour and minute with the ADJUST button.
Press SET for 2 seconds while in dual time mode and ADJUST +/- 23 hours from normal time.
Press MODE to exit most settings.
Press ADJUST in stopwatch mode to start/stop the timer accumulatively.
Press SET to reset stopwatch to zero, or split measurements if timer is running.
Change the battery with a new CR2025 to prevent damage that low or dead batteries can cause by leaking.
Do not use solvents to clean the watch, use only a dry or water moistened cloth.
Do not use buttons when the watch is wet. Water may penetrate the watch and cause damage to it.
on Dec 31, 2011 | Watches
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 | Watches
Can't set the digital time on Diesel DZ721
here are instructions from diesel:
http://store.dieseltimeframes.com/wcsstore/CommonDiesel/instructions/ENGLISH/Diesel_Digital-Guide_ENG.pdf
more specifically
TIME OF DAY MODE
1. Press C to toggle between Time 1 and Time 2.
2. Hold C for two seconds to set Time 1 or 2 as default.
3. Press D to turn on/off key tone.
Time 1
> To set Time, press A until hour flashes. Press B to select the setting
item. Use C and D buttons to adjust the values up or down. Press A to
exit set mode.
Time 2
item. Use C and D buttons to adjust the values up or down. Press A to exit set mode.
> The range difference between Time 1 and Time 2 is 23 hours.
CHRONO MODE
1. Press C to start and stop chronograph.
2. Press D to Split/Reset the chronograph.
3. Press A to recall the memory if Chronograph is stopped.
4. Press A again to view the next lap.
5. Press C or D to exit Recall mode and go back to Chronograph mode.
6. There are a total of 10 lap memories.
TIMER MODE
1. There are 3 different modes of timer: Count Down-Stop, Count DownRepeat, Count Down-and Up.
2. Press C to start/stop the timer counting.
3. Press D to reset the counter to the preset value if timer is stopped.
4. Press and hold A for 2 seconds to enter Timer Setting Mode. 35 Timer Setting Mode
5. Press B to cycle around the setting item: timer-type, hour, minute,
second and to back timer-type again.
6. Press C and D to increase/decrease the setting value.
7. Press A to exit the setting mode.
TIMER ALARM
Timer alarm will beep 2 times a second for 30 seconds.
ALARM MODE
1. Press C to select the alarm.
2. Press D to enable/disable the alarm.
3. Press B to change to Time mode again.
ALARM SETTING MODE
1. Press and hold A for 2 seconds to enter the alarm settings mode.
2. Press C and D to increase or decrease the settings value.
3. Press A to exit the settings mode.
Nov 19, 2012 | Watches
JAGA AD0919
Press and hold the mode button. Does a digit flash? If not try a "set" button. Once you get a digit flashing, you use one of the other buttons to change the digit. You can't do any damage so experiment.
Oct 15, 2012 | Bulova Watch
Set time on adidas Adults' Performance Duramo Watch
Mar 15, 2012 | Adidas Watches
How do I set the hour, minute, date etc.
Thank you for contacting FixYa.
    Setting the Time and Date
  1. To set the time and date on your Armitron digital watch, begin by pressing the "A" button while in time-telling mode. The seconds place will begin to flash; press the "C" button to reset the seconds to "00". Press "B" to set the hour, and press the "C" button repeatedly until the desired hour is reached. Press "B" to set the minutes, pressing the "C" button until the desired minute is reached. Press the "B" button, followed by "C" to set the month, date and day of the week. When you are finished programming the time and date, press "A" to save and return to time-telling mode.
  2. Using the Chronograph
  3. To use the chronograph feature on your digital Armitron watch, press "B" while in time-telling mode to access chronograph mode. Press the "C" button to start the timing; press "C" a second time to stop the timing. To reset the chronograph, press the "A" button. Press the "B" button at any time to return to time-telling mode.
  4. Using the Split Lap Chronograph Feature
  5. To use the split lap feature on an Armitron digital watch, press the "C" button while in chronograph mode. Press the "A" button to measure splits or laps; at the end of the event, press the "C" button to stop the timing. Press "A" once to see the final split or lap time, press "A" twice to reset the chronograph to "0". Return to time-telling mode by pressing the "B" button.
  6. Setting an Alarm
  7. To set an alarm on your Armitron digital watch, press the "B" button twice to access the alarm mode. Press the "A" button and wait for the hours place to begin flashing, then press the "B" button twice. Press the "B" button, followed by the "C" button to set the hour and minute of your alarm. When you're finished, press the "A" button to save the alarm. Press the "B" button to return to time-telling mode.
  8. Using the Countdown Timer
  9. To use your Armitron digital watch as a stopwatch, begin by pressing the "B" button three times while in time-telling mode to access the countdown timer mode. Press the "A" button, followed by the "C" button to set the hour. Press the "B" button, followed by the "C" button to set the minutes and seconds. Once you've set your timer, press "A" to return to countdown timer mode. To stop the countdown timer, press the "C" button. When you are ready to reset the countdown timer, press the "A" button. To return to time-telling mode, press the "B" button.
Best regards. Jewel
Sep 03, 2010 | Armitron Digital Sport #45/6967PNK Watch
Need instructions for Timex 1440 Sport watch
TIME AND DATE
CHRONOGRAPH
4. Press ADJUST to view lap time. Press again to sesume lap timing.
Nov 22, 2008 | Timex 1440 Nylon watch
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
Setting a generic one-button digital watch
I too lost the instructions for my generic 4 button digital watch and had to find the functions by trial and error and the results are below.
Adjust Alarm/Time/Date - Press and hold Mode Button. When alarm displays, release. Start-Stop Button SELECTS, Lap-Reset Button ADJUSTS selection. Pressing the Mode Button again changes from Alarm to Time/Date, ADJUST as above. Pressing it again exits.
Select/Deselect Alarm, Hourly Chime or Both - Press and hold Lap-Reset Button, Start-Stop Button TOGGLES through the above options.
Select 12/24 Hour Mode - Press and hold Lap-Reset Button, Mode Button TOGGLES through the above options.
Select Stopwatch - Momentarily press the Mode Button, use the Start-Stop and Lap-Reset buttons to control.
Display Date - Press Start-Stop Button in normal time
display mode.
Display Alarm - Press and hold Lap-Reset Button in
normal time display mode.
Cancel Alarm - Press Lap-Reset Button in normal time
display mode to silence alarm.
Hope this is helpful,
George.
Nov 06, 2007 | Watches
Watches Logo
5,078 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
