Question about Bosch Garden
What tool to use to adjust a chain saw carborator?
  • 60 Answers
Generally you should take it to a repair shop, as recommended in the manual. Those settings are set by mfr. Usually also, if you can get to them, use a screwdriver.
Posted on Apr 19, 2009
How to adjust a poulon pro chain saw 46cc 20" chain tighting
First, I'd read the manual if in doubt. No matter the type of adjuster, tool-less or not, you loosen the bar nuts, tighten the adjuster until the chain just touches the bar on the bottom (while holding the bar nose up) then tighten the bar nuts. Chain should move easily.
Re Poulan chain tightening. Be sure it's oiled and sharp, of course.
Aug 20, 2014 | Poulan Pro Chain Saw 46cc 20"
I have a husqvarna 435 chain saw and need to adjust carboorator but the adjustment screws have no way turning them. They are just round heads. New saw
There is a special tool required, the part no is 530035560 available from Husqvarna/Jonsered dealers, as posted earlier this should be a dealer adjustment as the machine is new.
Jan 03, 2011 | Husqvarna 450 e-series 18" Chain Saw
How do you adjust the carborator
If this is a late model saw, the adjustment screws have 'D' heads that need a dealer-only 'D' screwdriver. If the screws have slotted heads, then turn both screws CW to stops (lightly), then back each 1-1/2 turns CCW. This is a basic setting, so the engine should start and run. Start the engine and allow to warm up, then pull the throttle full on. Turn H CW until the engine speeds up, but still 4-stroking. When properly adjusted, the engine should 4-stroke, but immediately 2-stroke when cutting. Allow to idle and adjust L CW for fairly smooth running, yet allow the engine to 'follow the throttle'. Adjust idle speed screw to stop the chain from turning, yet the engine keeps running. Hope this helps!
May 20, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How to set carborator adjustment on Poulan Wild Thing 2375?
hello,the starting point for adjustment screws is 2 turns out.turn in til lightly seated so as not to damage them. there are 2 or more style carbs used on saw,some have plastic caps that need to be removed(a small metal screw used as a corkscrew or pry off) or you need a special tool -splined.set high spped til runs good and back off an 1/8-1/4 turn so you dont burn it up. fine tune low spped so it accelerates when trigger squeezed and re check high speed adjustment.single screw is for idle spped-raises or lowers-if chain turns while at idle back off screw.
mowerman33@verizon.net
Oct 05, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain saw.need rebuild kit for model 500vl carborator kit
what does a chainsaw have to do with a linksys router? but anyway try looking it up on google
Mar 18, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Need chain saw fix
I would try Poulanpro.com and look at their user manuals for the adjustment. They are different on most saws. Hope this helps
Mar 11, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
HOMLITE 33CC CHAIN SAW SPITTING WAY TO MUCH CHAIN LUBE
this homelite saw requires homelite chain oil as there is no adjustment.
Feb 12, 2009 | Dremel Variable - Speed Multipro Rotary...
Garden Logo
60 people viewed this question
Top Bosch Garden Experts
roeb
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Bosch Garden Expert? Answer questions, earn points and help others
