Question about Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher
Dishwasher shrot cycles then stops
Dishwasher appears to fill, then starts wash cycle. Cycle runs for a few seconds then stops. After about five seconds it starts again. It repeats this four times then turns off completely and all lights go off. Tried Maytag diagnostic (push Heavy wash 5 times, then Start) and it ended up with Light Wash & Clean lights blinking, but no error code in display. I replaced the handle a few months ago and just replaced one of the door switches that I had previously repaired. Thanks for your help. Nick
  • 2 more comments
  • Mike  Emanuel
    Mike Emanuel Jun 07, 2008
    Dishwasher fills, motor starts then shuts off after about 10 sec. Hit the drain button and the same thing happens..keps trying to run, then shuts down. Took off drain hose and completely disassembled pump...no clogs. Checked all wiring and protection/cutoff circuits. Worked fine prior to pulling it out to access the wall behind it for a plumbing repair.
  • Mike  Emanuel
    repair.
  • tractorwoman Aug 02, 2008
    My MDB7600AWW is doing the exact same thing. Fills with water, runs for 3 seconds, stops for 10 or 15 seconds, then this repeats 3 or 4 times before it shuts down, with the water still in it. It will drain if I run the rinse cycle, but when I try to run the dishwasher again, the same think happens. Tried normal wash and light wash - no success. Checked to make sure the washing arms weren't blocked too. In four years we have also replaced the handle THREE TIMES, the ENTIRE upper rack once, due to a tiny broken wheel, and the computer panel once, all to the tune of over $400 in parts. Needless to say we will not be purchasing another Maytag dishwasher!
  • mark548 Dec 05, 2008
    I am having teh same problem, Replaced the door latch assy this morning hoping that it would solve the problem. Will cycle and start to run 3 times then stops. When I open the door the tub will have water in it, press the start button twice and it will drain.
WT38UK commercial dishwasher needs reprograming/wash cycle too short an no rinse cycle?
The problem could be a defective controller rather than spontaneous return to factory settings.
Sep 04, 2018 | Electrolux Dishwashers
My dishwasher just beeps when I push start
Does it stop and run through its cycle after a few seconds ? Check this link
Oct 02, 2014 | Haier HDP18PA Portable 4 Cycle Dishwasher...
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
Fill Fault appears during wash cycle.
Is the filter in the hose where it screws onto the tap clean?, if this is okay then most likely the valve.
Apr 19, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I turn the dishwasher on normal wash and never stop washing i let it run for 2 hours and stiil running
Your dish washer probably has a "turbidity sensor". This is an infrared sensor that checks the condition of the water and adjusts your wash cycle accordingly. There is probably build up on the sensor (especially if you have hard water) and this is causing it to run so long. The easiest fix for this is to run a cleaning cycle on the dishwasher. Start your empty dish washer on a heavy wash cycle and wait for it to start filling with water. As soon as it starts to fill, open the door and pour 1/2 gallon of white vinegar into the bottom of the unit. Close the door and let it run its cycle. At the end of the cycle, run a second cycle and see if things improved. If things still are not better, you may have a bad sensor. If you have more questions, write me back. Hope this helps!
Dec 16, 2009 | Dryers
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher Logo
239 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
