Wiring of speakers with the amplifier. Also what type of speakers am I to connect.
Need to know how to set up speakers with the amplifier.
  • 4 more comments
  • maxaudiofile Apr 19, 2009
    I have a Nakamichi AV-10 receiver, which I misplaced the owner's manual for. I am trying to set up the speakers including center channel and subwoofer. can you send me the link for setup?
  • austin privitera Apr 19, 2009
    Just trying to hook up speakers to my receiver/amplifier. The model is Kenwood 105VR/KR-V5090
    Thanks. Much obliger. Regards.
  • austin privitera Apr 20, 2009
    Many thanks. Now I can operate!!!!! Regards
  • OnlyOneN
    OnlyOneN May 11, 2010
    Hi, I'm working on it for you. The manual isn't available online (that I could find). I'll let you know what I can find out.
  • OnlyOneN
    Could you clarify what you're trying to accomplish? Are you just trying to hook up speakers to your receiver? Or, are you integrating a separate amplifier into your setup?
    Also, could you let me know what model receiver / amplifier you have? I'll send you a link to the manual that will give clear directions.
    Sniper:
  • 86 Answers
For the Kenwood receiver, the manual is here:
http://inform3.kenwoodusa.com/manuals%5C105vr.pdf
or
http://tinyurl.com/cwuhbn
The instructions are on page 6.
Let me know if this helps!
Posted on Apr 20, 2009
  • OnlyOneN
    OnlyOneN Apr 22, 2009
    Sorry, but I've had no luck finding a PDF version of the user manual for you. You might want to try emailng Nakamichi here:
    http://www.nakamichi.com
    Click Contact Us / Nakamichi Offices.
How to hook up speakers
Dennis, Check the attached links diagrams,instruction and guides for hooking up speakers. Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Connect Stereo System Stereo Barn
How to Set Up Your Speakers with Receiver or Amplifier
amplifier wiring diagram Google Search
speaker wiring diagram Google Search
Aug 16, 2016 | Kenwood Audio Players & Recorders
Tip
How To Bi-Amp And Bi-Wire Speakers!
What is the difference between bi-wiring and bi-amping?
Bi-wiring is using the same power source (amplifier) but separately connecting that power source to a woofer and a midrange/tweeter on a speaker.
Bi-amping is using two separate power sources (amplifiers) and connecting one amplifier to a woofer and the other amplifier to a midrange/tweeter on a speaker.
How do I bi-wire?
Your speaker must have two separate positive and negative connections (one set for the woofer and one set for the midrange/tweeter). Connect one wire between the positive terminal on the amplifier/receiver the positive terminal on the speaker. Connect the other wire from the negative terminal on the amplifier/receiver to the corresponding negative terminal on the speaker. Remove the jumper straps connecting the two sets of speaker inputs. Repeat this process for the second set of terminals on the speaker, connecting them to the same positive and negative terminals on the receiver/amplifier. Repeat the steps for each speaker you wish to Bi-Wire, connecting them to the appropriate terminals on your receiver/amplifier.
How do I bi-amp?
Bi-amping is similar to bi-wiring, but involves separate amplifiers: one for the woofer and one for the midrange/tweeter. Passive bi-amping involves a direct hookup between each amplifier and the speaker terminals. True bi-amping involves hooking the preamp to an electronic crossover that replaces the passive crossover network in the speaker. The active crossover then connects to multiple power amplifiers.
on Jul 13, 2010 | Audio Players & Recorders
Need help wiring two 10" alpine type E subs to a alpine 500 watt monoblock amp
Just connect both sets of wires from the subwoofers to the same speaker output terminals on the amplifier. Make sure you keep the positive and negative wires together. This is called parallel wiring. The Type E is a 4-ohm, single voice coil subwoofer, so wiring them like this will give the amplifier a 2-ohm load, and the power produced will be divided between the two subs.
http://crutchfield.custhelp.com/rnt/rnw/img/enduser/Mono_2-4OSVC.jpg
Jul 16, 2015 | Alpine Car Audio & Video
I have Kicker ZX 650 4 channel amplifier and 4 DB drive PT6.2 mid range speaker. I want to hookup my speaker in 2 ohms. The operation manual for the amplifier can be used in 2 ohms. I need to know how to...
As far as I am aware you need to get 2 ohm speakers. I run a 4 ohm subwear as the Alpine Type R sub is 2 ohms. I'm not 100% on this though but you may get around it by bridging your speakers by connecting both speakers to the amp as normal but swapping the speakers negatives around! That may cause the amp to run as if only at 2 ohms. Hope this helped!
Feb 18, 2009 | Sony XM-2150GSX Car Audio Amplifier
Shutdown
There is either a thermal problem in the amp itself (a bad part) causing it to shut down after a while, or the amp is overheating due to a load problem. This may be due to wiring issues or a bad speaker. Try running the amp into a set of test speakers connected directly to the outputs with all the other speaker wiring disconnected. If the amp still shuts down you'll know the problem is in the amp itself. If it runs OK, you'll have isolated the trouble to the wiring or speakers and can test that portion.
Dec 10, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Car stereo wiring installation
red wire connect to accessories or constant power 12volt
black wire connect to earth /ground/ metal
yellow for clock and memory connect to permanent power
blue wire connect to amplifier
2x rc connect to amplifier
8x speaker wires connect to 4 speakers
just ask if you need more help glenn..........
Nov 22, 2008 | 2005 Mitsubishi Lancer
No sound new install
More information would be required to help you with this problem properly. If you are using an amplifier and have no sound from it, you may just have the remote turn on of the amplifier not connected. The radio should have a blue wire coming from it and that would be the wire that goes to the amplifier to turn it on when the radio is turned on. If the radio has no sound coming from the speakers connected directly to the radio, you may have a bad speaker, bad speaker wire, or even have the speakers connected wrong.
If you can please give me more information about the install, like what model radio, what type of amplifier, how you have connected the wiring, how many speakers and what the speakers are connected to (an amp or the radio), I can help you figure out the problem. But please understand, since I am not there to look at your install, I can not know how you have connected everything. Are you using a universal wiring harness to connect to the factory harness and your radio? Have you added extra speakers? What wires have you connected to the speakers? If you have an amplifier, have you connected the RCA output of the radio to the RCA input of the amplifier? There are many things that must be connected properly for a sound system to work, if you are not familiar with how they connect together you really should have a professional do it for you. If you furnish the needed information I will be glad to help you further. If you do not furnish the needed information there is really nothing more I can help you with.
Dave
Oct 12, 2008 | JVC Car Audio & Video
What then?
If you have an ohmmeter, you can verify the house wiring. Disconnect all the speakers from the amplifier. Disconnect the speaker wires from the speakers. Make sure none of the ends touch.
Connect the ohmmeter across each set of speaker wires. You should read an open circuit across each set of speaker wires. Basically if the meter gives you any reading, there is a fault somewhere on the line.
You could do the same test with the speaker wires connected to the speakers (but still not connected to the amplifier). You should see a reading greater than 4 ohms (and most likely less than 8 ohms) on each set of speaker wires. If you see a reading of 0 or 1 ohm on one set of wires, consider this suspect.
You mentioned earlier that you had 3 rear speakers each of 8 ohms... are they connected to one set of speaker wires at the amp? This would be an equivalent impedance of 2.7 ohms, and with loud volume, might be overheating a set of amp chips causing it to go into protect mode.
Let me know what you find.
Mar 24, 2008 | Onkyo TX-SR505 Receiver
Please help me!!
bwqueen-What type of vehicle are you installing it into,cause some vehicles have built in factory amplifiers.The ones with factory amps need a remote turn on to power up the speakers,let me know and I'll try to help you. cooltek Mar,4/08
Mar 02, 2008 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Wiring
The T10001 can drive a load lower than 4 ohms. Wire the coils of the individual speakers in series to make each speaker 8 ohms. Then wire all 3 speakers in parallel and connect them to the amp. This will give you a 2.6 ohm load.
Dec 01, 2007 | Rockford Fosgate T10001BD- Car Audio...
251 people viewed this question
 Grubhead
Grubhead
