Question about GE WWSE5240G
Washer will not spin or aggitate
This washer is only a year old and recently it stopped spinning and aggitating. it fills and drains fine. when i ran a diagnostic check, it said all systems were without fault, however, it also asked me to monitor the number of flashes coming from the motor circuit board...there were no flashes and i'm starting to think that the motor itself is bad. I don't feel like replacing the motor without a second opinion though.
  • Anonymous Sep 03, 2008
    WASHER WILL NOT SPIN OR AGITATE. THE DOOR SWITCH CHECKS OUT FINE. THE DRUM DRAINS FINE. BELT IS GOOD AND DRUM SPINS BY MOVING THE BELT. THE CIRCUIT BOARD LIGHT BLINKS 6 TIMES, I DONT KNOW THE CODES.
    WOWNT SPIN OR AGITATE. LID SWITCH CHECKS OUT FINE.
    LIGHT ON CIRCUIT BOARD BLINKS 6 TIMES.
1. unplug for ten minutes.
2. plug back in.
3. open/close lid 5 times.
4. wash clothes!
Posted on Feb 28, 2009
  • Michael McCulloch Feb 02, 2012
    We have been checking everything on this washer, thought it was loose pin connecter or wire but after washing 2 loads of clothes which did perfect spun out great, the 3 rd load well the final spin didn't work I found this and tried andnow it worked. I just hope this is not someting I will have to after every third load of laundry Thanks again
    Genius:
  • 1,003 Answers
MOTORS OF THIS TYPE JUST DONT GO OUT MOST LIKELY ITS A FAULTY POWER CONTROL MODULE
Posted on Feb 02, 2008
  • 975 Answers
Check the drain motor it could be clogged , clean it , and try again
Posted on Apr 17, 2008
SOURCE:
My whirlpool Estate washer is not draining or spinning but aggitates, what can be the problem?
Sounds like a cycle switch problem. The switch is not turning and making contact with the next cycle. It needs to be changed!
Jan 09, 2013 | Whirlpool Washing Machines
I have a GE washer (WBB4500G2WW) - wont aggitate or spin
The BELT... Part number wh01x10302
30% of the time is the issue here:
http://www.appliancepartspros.com/ge-belt-wh01x10302-ap3968432.html
Have a look at appliance-parts-pros (video guide)
http://www.appliancepartspros.com/repair-help/general-electric-washer-wbb4500g2ww-repair/wbb4500g2ww-pumps-but-will-not-spin.html
May require a specialty tool to mount the belt
(depicted in VIDEO... Sold on site): view here:
http://www.appliancepartspros.com/ge-service-kit-belt-wx05x20641-ap5957260.html
((not entirely convinced the tool is critical but the
Also check prices on eBay (top seller, free shipping
WH01X10302 AP3968432 1264395 PS1482278 WH01X10353 Washer Drive Belt eBay
Hope this holds off trashing your three year old washer...
Carnac the Magnificent
Jan 15, 2018 | Whirlpool Washing Machines
I have a MAYTAG washer that was having trouble in the spin cycle it would drain but would spin slower like the brake was coming on. Now it rinses and spins fine but during the wash cycle it fills then once...
More than likely it has a broken wire underneath that controls the spin. and agitation. I had an old Kenmore that the wire that controls these functions would break about every 6 months.
Apr 28, 2010 | Maytag Washer Timer - 22004015
Will not aggitate or spin,
lid switch remove back panel switch on rt rear corner could have microswitch or fuse depends on mdl #
Feb 04, 2010 | Maytag Washing Machines
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
Dec 04, 2009 | Maytag Washing Machines
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Washer fills and drains but won't aggitate or spin
Seven flashes means the washer did not sense a lid opening. Check the lid switch.
May 30, 2009 | General Electric WJRR4170GWW Top Load...
Kenmore 20842 won't spin or aggitate
Check your motor drive coupler. Tilt washer back against wall and look between motor and transmission . You will see a rubber grommet and two plastic couplers on each end of rubber , They may appear broken or you will see rubber shavings under washer.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Aggitator won't work and won't spin/ drains ok
Coupling is bad.
There is a coupling between the motor and the transmission. When this part breaks then it will pump the water out but won't spin or aggitate.
Jan 18, 2009 | Kenmore 15944 Top Load Washer
GE WWSE5240G Logo
557 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
